- Thank you received: 219
rear wheel bearings
10 Jun 2022 01:34 #45541
Replied by JIM.OBRIEN on topic rear wheel bearings
Thom, I'm glad it worked out! Now take it on a long drive to get the greese where it wants to be.
- Thom
09 Jun 2022 02:50 #45537
by Thom
Replied by Thom on topic rear wheel bearings
Jim, You idea worked great. Bearings packed and axles back onto thecar.
- Thom
04 Jun 2022 18:27 #45510
by Thom
Thanks Jim, That is the route I will take if I don't get any other solutions. It is accessible with the axle removed.
04 Jun 2022 02:15 #45507
I'm not firmiliar with the 8-101A but why do you have to pull the bearings off the shaft to repack them? You have access to the bearing, just repack them in place.
- Thom
02 Jun 2022 23:57 #45502
by Thom
rear wheel bearings was created by Thom
I am in the process of repacking the rear wheel bearings on my 1933 8101A Auburn. So far I've needed a wheel puller to remove the wooden wheel drums, a slide hammer to remove the axles from the rear housing and now I'm stuck at getting the bearings off the tapor axle. I am using a 3 jaw gear puller but they wont budge. I have been using P B Blaster with no results. Would someone tell me the trick to removing the bearings? Is it necessary to take it to a shop to have them removed professionally and then have them pressed back on? They were packed 2500 miles ago, still have grease in them, but need to be redone. Any advice would be very helpful. Thanks, Thom
