30-895
- 30-895
08 Dec 2022 16:46 #46549
by 30-895
Replied by 30-895 on topic 30-895
Also, I guess that I need a thermostat. Does anyone have a source for theses? What temp would be best?
- 30-895
30 Nov 2022 21:42 #46499
by 30-895
Things are moving along and progress is being made. May now need a set of gaskets for the Shebler Mod U carb. Does anyone have a source for these?
- 30-895
04 Nov 2022 14:45 #46349
by 30-895
Thanks, I'll give that a try.
- Thank you received: 219
04 Nov 2022 00:22 #46347
Replied by JIM.OBRIEN on topic 30-895
Try putting tablespoon or two of oil in each cylinder and see what the compression is. If the cylinder walls are dry you will not get a correct reading.
- 30-895
03 Nov 2022 14:35 #46331
by 30-895
Thanks again. I'll work on it.
03 Nov 2022 04:03 #46326
Replied by mikespeed35 on topic 30-895
What makes you think you have a compression problem? If you installed new pistons and rings but have not run the engine the rings will not have seated in the bores. Thus you will not have good compression untill the rings have seated. Thats presuming the cylinders were honed with a cross hatch pattern. Heads a blocks should be checked with a machinest straight edge!
CORDially MIke
CORDially MIke
- 30-895
02 Nov 2022 14:41 #46319
by 30-895
Does anyone know the correct compression ratio for this engine?
01 Nov 2022 21:40 - 01 Nov 2022 21:41 #46311
Replied by Curt Schulze on topic 30-895
Mike, I wish there was a LIKE button to check !
Last edit: 01 Nov 2022 21:41 by Curt Schulze. Reason: reword.
- 30-895
01 Nov 2022 21:17 #46310
by 30-895
The car isn't running so the test was done cold and dry. Head and block appeared to be OK and yes the head was torqued down properly. Probably going to check rings next. Thanks vey much for the reply.
01 Nov 2022 21:03 #46309
Were the cylinders bored? I think the compression should be more like 85 to 95. Did you have the carb. wide open when doing the comp. check? Are the valves adjusted properly? Was cylinder head and block surfaces flat? Is cyl. head torqued properly? Comp. gauge accurate? Just some things to check.
CORDially MIke
CORDially MIke
- 30-895
01 Nov 2022 15:04 #46306
by 30-895
30-895 was created by 30-895
Hello to all. I am working on my 1930 8-95 and seem to be having compression problems. New ring, pistons, valves, & gaskets have been installed. My question at this point is what should the compression be at 5200 feet. Compression is only at 35-50 depending on the cylinder. Any suggestions would be greatly appreciated.
Thanks Much
Thanks Much
