1933 Auburn gas tank
16 May 2023 03:58 #47213
Replied by mikespeed35 on topic 1933 Auburn gas tank
Why didn't I think of that! Help for bad spellers since we don't seem to have spell check anymore.
CORDially MIke
CORDially MIke
- pneflyer
15 May 2023 00:57 #47210
by pneflyer
Replied by pneflyer on topic 1933 Auburn gas tank
MEK
- pwrightII
14 May 2023 09:40 #47206
by pwrightII
Replied by pwrightII on topic 1933 Auburn gas tank
Thanks Mike . I appreciate it. Pete
14 May 2023 03:53 #47199
If you want to clean the tank yourself the solvent for the slosh is Methaleathelketon. I'm sure I spelled that wrong. All the same you put it in the tank and let it set on different sides for several hours doing it with new solvent till the slosh is gone. Its not easy or quick but it will remove the old slosh. I then sloshed again with ethenal friendly slosh and have had good luck with several cars in that manner.
- pwrightII
12 May 2023 18:02 #47192
by pwrightII
1933 Auburn gas tank was created by pwrightII
My 1933 Auburn 8-101 gas tank has an old liner flaking off. Does anyone manufacture a replacement tank or is my only choice to try to have the tank cleaned via boiling etc?
