- Thank you received: 44
600/650-17 tubes?
- wynlaidig
28 Jun 2023 23:29 #47369
by wynlaidig
Replied by wynlaidig on topic 600/650-17 tubes?
Thank you for the tip on installing replacement steps. That seems like a workable option.
- wynlaidig
28 Jun 2023 23:28 #47368
by wynlaidig
I did speak directly with Universal, but not with Longstone, although they only had offset available on their website. But I contact them directly to see if they can offer anything else. Thank you.
- vintagerodshop
25 Jun 2023 06:54 #47353
by vintagerodshop
Replied by vintagerodshop on topic 600/650-17 tubes?
Buy the size of tube you need. Cut out the incorrect valve stem. install a replacement stem of the size, type and location you need. Tire shops and farmers have been doing this for 100 years. It is really not that hard. I buy bent nickle valve stems from universal tire. The come with about a 3 inch rubber base for installing on tubes.
24 Jun 2023 20:20 #47349
Replied by johnmereness on topic 600/650-17 tubes?
You are talking with Universal Tire ? And, you have also spoken with Longstone in England ?
- wynlaidig
13 Jun 2023 01:20 #47309
by wynlaidig
What do others do? This has to be a problem for lots of people... Do people just cram in 700-19" tubes??
08 Jun 2023 02:55 #47304
Replied by mikespeed35 on topic 600/650-17 tubes?
L-29 Cords have the same trouble only 18" tubes. No center valve stems! I had a Firestone engineer take pitty on me years ago and make me six at no charge. But that was when they were still making tubes in the USA.
- wynlaidig
07 Jun 2023 18:50 #47300
by wynlaidig
600/650-17 tubes? was created by wynlaidig
Has anyone purchased tubes for 600/650-17 tires recently? The only tubes this size that I can find have offset valve stems, but the Auburn rims have center stems. I can get bent brass center stems, but they are so long they stick outside the tire profile. I talked to Coker, Universal, and Lucas. They said the only option is to go to a 19" tube to get a centered rubber valve. Is there really no other option?
