Schebler duplex carburetor information
- Ivor
09 Apr 2024 07:58 #48401
by Ivor
Replied by Ivor on topic Schebler duplex carburetor information
Hello Vic, thank you for your reply, I will contact you via e-mail.
Ivor.
Ivor.
- vicfreg
07 Apr 2024 22:54 #48394
by vicfreg
Replied by vicfreg on topic Schebler duplex carburetor information
Hi Ivor. We have a 1928 8-90 with one of those Scheblers. I have lots of pictures of this carb when we took it apart. So, if you still need this info, let me know
Vic Fregonese
[email protected]
Vic Fregonese
[email protected]
- Ivor
02 Sep 2023 05:15 #47648
by Ivor
Schebler duplex carburetor information was created by Ivor
Hello, I am seeking information to help a fellow Auburn owner. His car is a 1928 8-115 and the Carburetor is a Schebler Duplex with cast brass bowl number SX312. I am after any information on the correct air vale spring, needle valve seat (main jet) and correct needle valve number or taper. The existing needles have 10 rings or grooves and from the information I have are 7 degree taper, the needle valve seats are new from "Straight eight " and measure 0.039" the Air valve spring is 1.061" outside diameter 8 1/2 active coils, 3.9" long with 0.042 diameter wire. Any information appreciated.
Ivor.
Ivor.
