Frame stamping question
- CTCraig
11 Sep 2023 13:28 #47691
by CTCraig
Replied by CTCraig on topic Frame stamping question
Oddly enough, same situation on my 1931 Auburn. The VIN tag and title had 2 numbers reversed. The tag was a repro, but I knew the frame was correct so I made a new VN tag, took the car to DMV for inspection and had a new title generated with the correct VIN. When I discovered a record of the original owner with VIN and engine number they matched the frame. Somewhere along the line, someone transposed 2 numbers.
07 Sep 2023 14:39 #47677
Replied by Curt Schulze on topic Frame stamping question
Many newer vin tags are stamped with modern font. Compare it to a known old tag.
The following user(s) said Thank You: ilikescars
07 Sep 2023 13:38 #47675
by ilikescars
Replied by ilikescars on topic Frame stamping question
Not sure if it's original. That's a good point: the VIN may have been accidently misprinted on the title.
06 Sep 2023 13:51 #47669
Is the vin tag original ?
05 Sep 2023 14:10 - 05 Sep 2023 14:16 #47664
by ilikescars
Frame stamping question was created by ilikescars
I have a 36 Auburn Cabriolet that has a VIN number of 5917F. I understand that the frame # should be 1 thousand less: 4917. I found the frame number to be 4971. May be that the factory worker was dyslexic? Has anyone ever run across this?
Last edit: 05 Sep 2023 14:16 by ilikescars. Reason: misspelling
