- Thank you received: 11
Pitman arm for 31 Auburn
- Brad Hoskins
13 Sep 2023 00:40 #47705
by Brad Hoskins
31 8-98 cabriolet
Replied by Brad Hoskins on topic Pitman arm for 31 Auburn
As was mine, In fact , it had worn enough that the drag link had cut a groove in the neck right before the ball.
Rare Parts was able to rebuild the pitman arm and supply ball studs to rebuild the tie rod ends.
I can't remember what they charged as it was quite a while back , probably will look reasonable in hindsight!
Brad
Brad
31 8-98 cabriolet
The following user(s) said Thank You: danc2003
- danc2003
12 Sep 2023 22:05 #47702
by danc2003
Replied by danc2003 on topic Pitman arm for 31 Auburn
The ball is worn on the sides
12 Sep 2023 20:56 #47701
Replied by 1748 S on topic Pitman arm for 31 Auburn
Having never seen an Auburn pitman arm my belief is the bend in the end is correct. The splines appear fine. Lets see what the experts have to say.
- danc2003
12 Sep 2023 19:12 #47700
by danc2003
Here’s the pics.
12 Sep 2023 12:04 #47699
by pete kelly
Replied by pete kelly on topic Pitman arm for 31 Auburn
Post a pic of it; I may have 1.
Pete
Pete
- Brad Hoskins
12 Sep 2023 04:20 #47698
by Brad Hoskins
31 8-98 cabriolet
Rare Parts repaired mine, not cheap but I think your options are limited!
They seem to know what they are doing.
www.rareparts.com/
Brad
www.rareparts.com/
Brad
31 8-98 cabriolet
- danc2003
12 Sep 2023 00:34 #47697
by danc2003
Pitman arm for 31 Auburn was created by danc2003
Hello I’m looking for a pitman arm for my 31 sedan. Or is there a way to repair it. Appreciate any help.
