Columbia Two-Speed Axle
- sdbraverman
29 Oct 2023 23:08 #47902
by sdbraverman
Replied by sdbraverman on topic Columbia Two-Speed Axle
Do you know the axle ratio? Best to know so you are not disapointed.
I do not know the ratio, but it was installed in an identical car and it performed great.
29 Oct 2023 22:43 #47901
Replied by mikespeed35 on topic Columbia Two-Speed Axle
- sdbraverman
29 Oct 2023 03:13 #47899
by sdbraverman
Columbia Two-Speed Axle was created by sdbraverman
Who are the Columbia axle experts? This is supposedly from an Auburn V12, but was adapted many decades ago to fit a 1932 Franklin. The spring perches, and shock mounts have been moved to fit the Franklin. It has Franklin brakes. I plan to reinstall it into my 1932 Franklin. It had been setup to shift manually using a lever on the floor. I crawled under an Auburn 12 at Hershey and saw a bunch of hoses connected to the axle and a switch on the dash to shift it.
What are my options for a clean, reliable install into my Franklin?I would also like to find any info regarding servicing and maintenance on this.
