1935 1936 dual ratio rear end
05 Dec 2006 18:03 #5893
Replied by Curt Schulze on topic Six Cylinder Bolt Pattern
The Auburn Six cylinder cars have a 4 3/4 bolt pattern.
- Jan
04 Dec 2006 21:15 #5891
by Jan
Replied by Jan on topic Difference in Columbia between 6 and 8 cyl?
As you say that a 6 and 8 cyl rear ends only have different axles and hubs
-does that mean that the 6-cyl has 5 inch wheel bolt diameter ?
- I know that the 8-cyl has 5.5 inch like the older Fords 40-48.
It would be nice to know - despite all info I have I have not seen it anywhere. There is a Columbia for sale here and it has the 5 inch diameter type. /Jan L
27 Oct 2006 01:49 #5664
Replied by Curt Schulze on topic 1935 1936 dual ratio rear end
In 1934 - 1936 dual ratios were available in both 6 and 8 cylinder cars.
The ratio that came in it from Columbia is stamped in the front side of the carrier housing along with the assembly date. 6 & 8 dual ratios are exactly the same except for the axles and brake backing plates.
- sharknose1
26 Oct 2006 20:27 #5662
by sharknose1
Replied by sharknose1 on topic 1935 1936 dual ratio rear end
I have another question.Does anybody know what the gear ratio is in these rear ends?
- sharknose1
26 Oct 2006 00:52 #5656
by sharknose1
Wow!That was fast.Thank you for the info.
26 Oct 2006 00:13 #5655
by
Replied by on topic 1935 1936 dual ratio rear end
And all 12 cylinder models
- Chris Summers
25 Oct 2006 23:41 #5654
by Chris Summers
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
Replied by Chris Summers on topic 1935 1936 dual ratio rear end
Brian,
8-cylinder models for '32-'33, six-and-eight-cylinder models for '34-36.
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
- sharknose1
25 Oct 2006 22:24 #5651
by sharknose1
1935 1936 dual ratio rear end was created by sharknose1
I have a dual ratio rear end listed on EBay and was asked a question that I can't answer.Was the dual ratio rear ends offered on just 8 cylinder cars or all cars of those years?Any info would be appreciated.Thanks,Brian
