fuel.oil presure,and supercharger tube sizes
02 Jan 2007 02:35 #6062
by ilikescars
Replied by ilikescars on topic Tubing
Mike: To answer a couple of questions: The supercharged cars had the larger diameter fuel lines, including the pickup tube in the gas tank.
That flexible line at the pressure regulator is correct. It was installed on later cars to correct problem with breakage due to engine vibration & movement.
Regards, Mark
Regards, Mark
01 Jan 2007 18:39 #6061
fuel.oil presure,and supercharger tube sizes was created by mikespeed35
These questions relate to a 35 Auburn Speedster I'm working on. The supercharger has a oil supply tube and a oil drain tube. What is the size of the supply and drain back tubes? Do they use reverse flair fittings?
Does the oil pressure gauge tube [1/4"] have a flexable hose at the pres. reg. end? Mine did and another I observed, but it doesn't seem right to me. If it does have such a hose where do I get one?
My car has a 5/16" fuel tube from the gas tank to the fuel pump. The parts book calls for a 1/4" tube. Is the 5/16" for supercharged cars only?
Are all the fittings for the above tubes reverse flair?
Cordially Mike
Cordially Mike
