Plugged gas gage
- Chris Summers
Curt Schulze wrote: I heated it on the out door bar-b-que at 150-190 degrees for 3 hours.
Isn't it amazing how car guys like us can adapt ANY household object into a shop tool?
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
John, if you ever want to get rid of the red ribbon, I have working calibrated gages with the correct manometer fluid for $150.
I have been thinking about your problem. I used lacquer thinner to clean mine but they were not plugged. This is a little radical but what if you put the type of cleaner you want to try in the brass tube and then adapt a grease zerk to the threads of the tube and very carefully pump some grease into the tube to put a little pressure on the cleaner. I say a LITTLE PRESSURE. The alternative is to keep pumping and I guarantee something will give but it probably won't be the plug. I said it was radical.
I will be trying toilet bowl cleaner and fuel injection cleaner and post the results.
- mason maynard
What We need is a chemist.
,dental Labs etc, CORDially Mike
I was only able to clean the tube out w/the wire a good inch below the capillary tube, but it was hours of "fun" to even get to that point.
- russv
Have you tired a little fuel injector cleaner? I have used to clean small engine float bowls.
Russ
I am open to suggestions.
- steve pugh
Did the vinegar work for you?
Steve
- steve pugh
fuel gage in the 1934-1936 Auburns. <!-- s:? --><img src="{SMILIES_PATH}/icon_confused.gif" alt="" title="Confused" /><!-- s:? -->
