Preventing rust on hinges
- Frank Guzik
27 Nov 2011 00:11 #21497
by Frank Guzik
Frank Guzik
1931 Auburn 898-A
Auburn IN
Replied by Frank Guzik on topic Preventing rust on hinges
Mike,
4 years and 20,000+ miles in weather most of us will never see in our cars. I think you have a good testament to lasting power.
Frank
Frank
Frank Guzik
1931 Auburn 898-A
Auburn IN
22 Nov 2011 04:31 #21473
Replied by mikespeed35 on topic Preventing rust on hinges
I have stainless door pins in my 35 and have had no problems, but it has only been 4 years.
- IndycarBruce
22 Nov 2011 02:26 #21472
by IndycarBruce
Replied by IndycarBruce on topic Preventing rust on hinges
Mike,
The door hinges are in great shape.
The pins for the rumble seat lid hinges aren't sloppy, but I discovered one pin has a nasty groove worn into it where a set screw was on one side. I'm thinking I'll make new pins from 5/8" dia rod. If I make the pins from stainless steel I wouldn't have abnormal corrosion problems with the cast iron hinges would I?
Bruce
Bruce
21 Nov 2011 23:17 #21470
Are the hinge pins sloppy know that the rust is gone? Reaming with new pins might be in order.
- IndycarBruce
21 Nov 2011 03:37 #21466
by IndycarBruce
Preventing rust on hinges was created by IndycarBruce
I've been soaking parts from my 29 Auburn in a gallon of EvapoRust. On some badly rusted parts, I had to soak them about two days, but it worked great.
I have some questions about the hinges. On the door hinges, the rust cleaned up effortlessly and the movement was good. Did they nickel plate the hinges back then?
Regarding the cast iron rumble seat lid hinges, these were badly rusted but after about 36 hours, they're almost rust free. Now, is there a good coating that I could apply to the hinge pins and bores, that I could then mask off when I paint the hinges? I was wondering about electroless nickel.
