Carburetor Question
12 Feb 2013 05:43 #24475
by ilikescars
Replied by ilikescars on topic Carburetor Question
Those were installed to keep those pesky flying insects from clogging up the innards.
- Thank you received: 135
11 Feb 2013 21:56 #24474
Replied by 1748 S on topic Carburetor Question
I would remove it for all the above reasons posted. Being a soft material I can't see it harming any internal parts but hanging open a valve may be an issue too or hanging open the throttle butterflys. Removing it will not harm anything that I can see.
- DavidK
11 Feb 2013 00:05 #24469
by DavidK
Replied by DavidK on topic Screen
I've never seen anything like it either. It is located on the air cleaner side,(air inlet). I was planning to removing it. I don't think I trust it. I'm not really familar with these carburetors so I wanted to check before removing it. Guess it shows how big a concern gas mileage has always been.
Dave
Dave
- silverghost
10 Feb 2013 23:53 #24468
by silverghost
Replied by silverghost on topic Very Strange Screen Indeed !
I have never seen such a brass screen on any carb I have ever worked on, or rebuilt . And there have been hundreds .
Just curious if this screen is on the underside of the throttle plate butterfly; or on the top air comming in side ?
For years there have been many aftermarket worthless snake-oil style products sold to improve fuel milage
ie. magnets clamped on the fuel line, ignition power boosters, screens under the carb, where it's mounted to the intake manifold. etc.
I would guess the idea was to increase turbulance & break up fuel mist droplets into a much smaller size.
The only thing these aftermaket products really did for anyone was to make money for those who sold them !
Perhapps this is one of those crazy ideas & virtually worthless aftermarket products ?
I suspect it does more harm~~~than good !
Many owners also liked to experiment on carbs & ignitions also.
Perhapps this is one such prior owner's nutty idea ?
Possibly some owner's idea of how to retain the throttle plate butterfly mounting screws ?
I would be afraid the sreen, or part of a wire from it, might be sucked into the intake manifold & engine with very bad damaging results.
Also the screen, or a wire from it, might keep the throttle plate from opening & closing properly and cause a run-away throttle & engine condition.
If it were me~~~i would remove it !
Let's see what others say about it.
Very strange screen indeed !
10 Feb 2013 22:16 #24467
Replied by Curt Schulze on topic screen
IMHO that is not factory.
- DavidK
10 Feb 2013 20:12 #24466
by DavidK
Carburetor Question was created by DavidK
I'm rebuilding a Stromberg carburetor and found the throttle butterfly plate has a copper mesh soldered to it. Has anyone ever seen this before? I don't know if it was added as a way to improve atomization or if it even came that way. My parts drawing doesn't really show it. Has anyone ever come across this? I wonder if it works or does more harm. It's only on the one side.
Dave
Dave
