need a fuel pump for a 1929 Auburn
25 Sep 2017 23:15 #33604
Replied by 1748 S on topic need a fuel pump for a 1929 Auburn
If you can't locate a pump you can use some RTV to patch this crack. Just install the fitting. Then force into the crack the RTV. Not enough pressure there to cause a leak with the RTV forced into the crack.
The following user(s) said Thank You: GasWorksGarage
- GasWorksGarage
25 Sep 2017 19:07 #33603
by GasWorksGarage
need a fuel pump for a 1929 Auburn was created by GasWorksGarage
Hello,
I am in need of a pump as mine is cracked where the fuel inlet is. I have been told its AC Part # J1-132.
Anyone have one or can lead me to one?
