8-105 - Strange slits cut into lower side skirts of Pistons????
- auburnandyscar
27 Dec 2017 02:58 #33951
by auburnandyscar
Check out my build at:
www.1932auburnsedan.com
Replied by auburnandyscar on topic 8-105 - Strange slits cut into lower side skirts of Pistons????
As mentioned earlier, it is for the skirt to expand.
Our friend, Mr. Zollner, had not yet invented the "Barrel curved" Piston.
Many,Many Technological advances during this time
- curtiss
26 Dec 2017 03:32 #33948
by curtiss
Replied by curtiss on topic 8-105 - Strange slits cut into lower side skirts of Pistons????
- curtiss
25 Dec 2017 17:30 #33945
by curtiss
Merry Christmas to you too! Thanks for the info.
25 Dec 2017 17:24 #33944
by RandyEma
Replied by RandyEma on topic 8-105 - Strange slits cut into lower side skirts of Pistons????
Merry Christmas . The factory used them to allow for expansion so the skirt hot would not score to the cylinder wall. R
- curtiss
25 Dec 2017 11:11 #33940
by curtiss
So is it acceptable to reuse these? What is the purpose, to get more oil in?
25 Dec 2017 05:13 #33939
Replied by mikespeed35 on topic 8-105 - Strange slits cut into lower side skirts of Pistons????
Not strange, common for the era.
- curtiss
25 Dec 2017 04:23 - 25 Dec 2017 04:27 #33937
by curtiss
8-105 - Strange slits cut into lower side skirts of Pistons???? was created by curtiss
We finally got to pulling the engine and taking it apart tonight in the 1933 8-105.
I found each of the pistons we labeled .060 over and they had a hole drilled in the skirt along with a "T" style slit in the sides of Pistons below the ring level. I have never seen this before, have you all seem this and what would the reason be for doing this?
Last edit: 25 Dec 2017 04:27 by curtiss.
