Recommendation on Tube Brands and sources 600/650-17???
20 Mar 2018 14:56 #34343
Replied by Curt Schulze on topic Recommendation on Tube Brands and sources 600/650-17???
I run Lester 600/650 (really 6:00's) in the sidemount pockets & the Bedfords on all fours. If you want originality, ditch the white-walls or have them on both sides of the tire . Single sided white-walls first appeared in 1939. If you follow the AACA forums at all , you would steer clear of the 'other tire company'.
- WinAuBurn
20 Mar 2018 14:25 #34342
by WinAuBurn
Replied by WinAuBurn on topic Recommendation on Tube Brands and sources 600/650-17???
Was the 600/650-17 original equipment for the ’31 Auburn? We currently have 700’s but are looking to change these out to prepare our car for vintage rallying. Those of you following our thread on this know there have been many questions about correct gearing which begs a question. Switching from say a Lester 600/650-17 up to say a Coker/BFG 750 provides a gearing adjustment of around 15 if my math is correct. Are the 750’s ok for this setup if we want longer gearing? I do like the cut of the Bedford 750-17.
19 Mar 2018 21:07 #34340
These Bedfords came from Lucas
- curtiss
19 Mar 2018 20:28 #34339
by curtiss
Replied by curtiss on topic Recommendation on Tube Brands and sources 600/650-17???
I looked at Lucas and it appears their Firestone is also 4 ply, not sure if they are the same tire as Coker or not but same spec. in the whitewall 600/650-17
19 Mar 2018 20:23 #34338
NO, check out post #2
- curtiss
19 Mar 2018 19:01 #34337
by curtiss
Is there a source for the 6 ply Firestone or are we stuck with what we can get form Coker?
- DavidK
19 Mar 2018 17:46 #34336
by DavidK
Replied by DavidK on topic Recommendation on Tube Brands and sources 600/650-17???
Just for reference, a 600/650 - 17 Firestone from Coker, four ply tire versus a 6 ply tire, are not the same size and have different tread. The six ply has the same zig zap patter but more aggressive looking.
Dave
Dave
19 Mar 2018 17:24 #34335
Lucas Tire Co.
- curtiss
19 Mar 2018 15:32 #34334
by curtiss
Recommendation on Tube Brands and sources 600/650-17??? was created by curtiss
We are getting ready to replace the tires on our 31 Auburn which at this point I am planning on getting form Coker Tire. In the past when I bought there tubes years ago I had issues so I figured I would ask what your experience has been regarding tube brands and sources.
If you were buying new tubes today what would your tube recommendation be? I see some with rubber stems and some with Nickel stems, Also recommendations for the inner rubber rim flap?
