Has anyone made an 851/852 Speedometer cable recently ?
21 Apr 2020 15:06 - 21 Apr 2020 15:08 #39985
Replied by johnmereness on topic Has anyone made an 851/852 Speedometer cable recently ?
Thanks, I will get into it and see what needs done. I made one once for the 1930 Franklin 147 Speedster Series Convertible Sedan and very fortunately over 100's of car projects have never needed to make another or could buy easily enough. The Auburn struck me as a bit more of the challenge via it being so long - 10 plus feet as it goes from dash forward through cowl and then under entire car to rear axle. And I have tried to avoid parts fabrication of any sort for the Auburn relying heavily on others (it has been nice to fry other fish).
Last edit: 21 Apr 2020 15:08 by johnmereness.
- Thank you received: 219
19 Apr 2020 19:35 #39983
Replied by JIM.OBRIEN on topic Has anyone made an 851/852 Speedometer cable recently ?
Try NAPA or your local auto parts store. They have universal kits in different diameters and lengths. You cut it to length and swedge the end on with the tool tin the kit. I've used them many times with no problems.
19 Apr 2020 17:58 #39982
by pete kelly
Replied by pete kelly on topic Has anyone made an 851/852 Speedometer cable recently ?
Hi John
If you are having a problem I have a couple boxes in inner cable and a tool.
Pete
Pete
19 Apr 2020 05:14 #39977
Replied by mikespeed35 on topic Has anyone made an 851/852 Speedometer cable recently ?
Try Restoration Supply in CA. Just bought some cable for my Mitchell. The sell several Dia. and ends. Not having the proper crimping tool for the ends I solder them on, works good.
18 Apr 2020 22:02 #39973
Has anyone made an 851/852 Speedometer cable recently ? was created by johnmereness
Has anyone made an 851/852 Speedometer cable recently ? I looked in the box and quickly saw only one end of internal cable was showing itself - so assume it is broken. I will have to get it out and really look at it, but probably needs a new internal cable (external cable housing should be fine). Where did you purchase ? I ask as they do not make cables much larger - maybe in some sort of truck = it has to be 10 feet plus.
