1932 Auburn 8 Cylinder Oil Pressure
- ttcinc
- ttcinc
I found the culprit on the oil pressure. It was the relief valve not working properly.It had the wrong spring in it.
- ttcinc
- Brad Hoskins
- Thank you received: 11
Mike, can you advise what size the restrictor orifice should be?
As for your steering box question, I sent mine to Lares .The voodoo they did was about $700. I don't think there are any other options . Finding bearing parts for the sector tapered bearing peg is impossible. I don't know what Lares does in there and I'm not about to take it apart to find out!
Brad
31 8-98 cabriolet
- ttcinc
Thank you
Pete
- ttcinc
Thank you
- ttcinc
- Ivor
- Ivor
Ivor.
- ttcinc
- Thank you received: 136
- ttcinc
