- Thank you received: 305
electric fuel pump
17 May 2022 07:37 #45427
Replied by Terry Cockerell on topic electric fuel pump
Thanks Mike, no wonder I had trouble trying to find the company on the Internet.
17 May 2022 03:37 #45424
Replied by mikespeed35 on topic electric fuel pump
Everyone should be aware that Airtex has not made fuel pumps for 2 or 3 years. The pumps you see on the internet advertised as "Airtex" are not! The picture you see in these adds is not the pump you get in reality.
- [email protected]
- Thank you received: 7
13 May 2022 17:34 #45402
by [email protected]
Replied by [email protected] on topic electric fuel pump
I have this set up, works a treat, use a sneaky switch under the dash to use it when required. If the manual pump should fail you have a back up too.
13 May 2022 07:34 #45399
Sorry I can't find any pictures of the installation.
The pump I used was a low pressure Airtex.
11 May 2022 20:34 #45391
You will require a low pressure 6 volt pump placed close to the fuel tank. This can be fitted under the floor where it is raised up to clear the rear axle. You will also need an in line filter. I will have to check what brand of pump I have and post some pictures.
- Vettepit
11 May 2022 14:47 #45388
by Vettepit
electric fuel pump was created by Vettepit
i would like to add a electric fuel pump to prime the system after car has been sitting over the winter,
what are the the best options to do this?
Thank you
Thank you
