- Thank you received: 305
Water in exhaust
12 Jul 2022 05:57 #45666
Replied by Terry Cockerell on topic Water in exhaust
Pat the simplest solution is to block the coolant from entering the inlet manifold completely. My engine ran fine with the coolant just passing through the heads.
There is a vent hole in the top of the block that connects with the inlet manifold. This needs to be sealed off with a tapered plug.
12 Jul 2022 03:57 #45665
Replied by mikespeed35 on topic Water in exhaust
Don't know much Pat but Ray Parker had simillar problem and he had a leak on the bottom of the intake manifold where a hole had formed from corrosion. Maybe a hole in one of the intake runners?
- Pat Leahy
- Thank you received: 28
11 Jul 2022 20:24 - 11 Jul 2022 20:27 #45659
by Pat Leahy
Pat Leahy
Water in exhaust was created by Pat Leahy
I recently had a problem with my Cord Taxi. When driving home from a car show, with my wife following in her 1956 Packard 400, I started to see some white smoke. Made it home OK. Well I finished my head gaskets on the taxi, but it didn't fix water in exhaust system. 2 left cylinder seems to be the one with water. It had low compression before installing new head gasket (40#). After installation I have 70#, other cylinders are similar. It may
also be adding water to oil. Intake manifold water leak?
Pat Leahy
Last edit: 11 Jul 2022 20:27 by Pat Leahy.
