Fuel gauge
- Stroy0809
21 Jul 2022 19:56 #45724
by Stroy0809
Replied by Stroy0809 on topic Fuel gauge
pat
did you get my check? Has the fuel sensor gone out?
- Pat Leahy
- Thank you received: 28
12 Jul 2022 20:58 #45669
by Pat Leahy
Pat Leahy
Replied by Pat Leahy on topic Fuel gauge
$60.00+ $10.00 shipping.
Pat Leahy
9727 Mettert Road
Woodburn, IN 46797
260-444-6460
[email protected]
Pat Leahy
9727 Mettert Road
Woodburn, IN 46797
260-444-6460
[email protected]
Pat Leahy
- Stroy0809
12 Jul 2022 02:39 #45664
by Stroy0809
Thanks for that info. How much is a new sender. I think it pays to change it and eliminate one thing at a time.
- Pat Leahy
12 Jul 2022 02:15 #45663
by Pat Leahy
Pat Leahy
The button on the fuel gauge changes the display reading from fuel level ( button not pushed) to oil level ( button held down). Both the gas tank and oil pan have similar senders. Grounding the wire from the sender should show a full reading. The gas tank sender is accessible from inside the trunk (unscrew small oval plate). I have modern replacement gas tank senders available if you need one. Many times the button is the reason for poor display and can be eliminated giving you only a gas tank reading.
Pat Leahy
- Stroy0809
12 Jul 2022 00:40 #45662
by Stroy0809
Fuel gauge was created by Stroy0809
Help with fuel gauge. I don’t get a reading all the time or one that’s accurate. I push the button on the gauge and sometimes it registers others not. Not accurate either. How does the gauge work and is there replacement sensors?
