Cord trunk question
- Thomas Wilcock
25 Nov 2022 20:11 #46466
by Thomas Wilcock
Replied by Thomas Wilcock on topic Cord trunk question
Russ:
Email me at [email protected] and I can give you dimensions of the wood for the Phaeton trunk opening.
Tom
Tom
- wolfpline
25 Nov 2022 02:10 #46460
by wolfpline
Replied by wolfpline on topic Cord trunk question
Tom I have no wood at all for my Phaeton, how can I get in touch with you to get dimensions/patterns?
Russ
Russ
- fireguyfire
01 Nov 2022 20:10 #46308
by fireguyfire
Replied by fireguyfire on topic Cord trunk question
PM sent
01 Nov 2022 19:50 #46307
by uconn_1965
Replied by uconn_1965 on topic Cord trunk question
HinTodd: I don’t mean to hijack this thread but it’s the only way I can reach you. You mentioned you wanted to purchase my NOS Autolite coil but I still haven’t received payment. If you have changed your mind, let me know and I’ll re-list the coil on the club web site. Thanks, Cliff
- fireguyfire
31 Oct 2022 13:26 #46305
by fireguyfire
As always, thanks for the info gents, and I very much look forward to receiving the templates Terry!
There are supposed to be thin metal pieces that cover the wood surround once it’s installed and they are painted body colour. The passenger side vertical piece of the trunk wood cover is still there on my car (with no wood behind it) but the rest are gone.
If anyone has some extra of these laying around I would be interested in them!
- Thank you received: 305
25 Oct 2022 23:17 - 27 Oct 2022 22:32 #46276
Replied by Terry Cockerell on topic Cord trunk question
Todd the hinge mounting in the sedans is different to the phaeton.
You are lucky as I saved all of the original wooden pieces from the frame in my Westchester.
I can send you templates. What is your postal address?
Send it to my home email .......... [email protected]
There is also metal sheeting covering all of the wooden frame. I see you have the lower strip of wood that goes between the body and cross member.
Last edit: 27 Oct 2022 22:32 by Terry Cockerell. Reason: Revising text
- Thank you received: 135
25 Oct 2022 22:24 #46272
Replied by 1748 S on topic Cord trunk question
My 37 Beverly sedan does NOT have any wood around the Bustle trunk or inside the body. It actually has outside lid hinges. They are a close replacement the Chryslers have so you can purchase plenty of those on ebay really cheaply. Last I checked I had 2 complete hinge sets. My 37 was built in the first or second week of January 37 and its defeinantly NOT a renumbered car. So dictates in the engineering change book.
25 Oct 2022 20:34 #46270
I am pretty certain that the timber frames are different with the sedan and phaetons. As an example in the parts book there are three separate fuel tank filler lids for the sedan, phaeton and cabriolet.
- fireguyfire
25 Oct 2022 12:19 #46257
by fireguyfire
Hi Tom, thanks for the photos. I’m assuming that no one reproduces the wood pieces, so I will have to make replacements. Luckily I have a full wood shop as well.
Dimensions would be greatly appreciated!
- Thomas Wilcock
25 Oct 2022 11:19 #46256
by Thomas Wilcock
25 Oct 2022 01:21 - 25 Oct 2022 08:02 #46255
There is a timber frame which fits around the inside of the trunk opening.
There are also some wooden blocks at the top of the frame to which the hinges are attached.
I still have the original timber framing which I can take some pictures of and post in a day or so.
Last edit: 25 Oct 2022 08:02 by Terry Cockerell. Reason: Revising text
- fireguyfire
25 Oct 2022 00:01 #46254
by fireguyfire
Cord trunk question was created by fireguyfire
So I was thinking about rough fitting the trunk lid I sourced for my 1936 Cord and seeing how it bolts up.
I noticed there are 4 wood screws above the trunk opening when I was stripping the overpaint from the car, and knew obviously they are not correct. Today I decided to have a closer look at why they are there, and they are screwing into a wood block on each side of the trunk lid hinges, and one side of each hinge is attached to it. The other side of each hinge has 3 holes that clearly are for also attaching the hinge to the car for support, but there is nothing there on either hinge.
im guessing there is supposed to be a wooden interior surround for the hinges to bolt to originally? Can someone describe or better post a photo or 2 of how the trunk lid hinges are supposed to correctly be fastened to the car?
