Cigar Lighter
01 Dec 2022 04:23 #46500
Replied by mikespeed35 on topic Cigar Lighter
Your right as always Pete. Sorry, I got that wrong. Laura is right!
30 Nov 2022 18:26 #46498
by pete kelly
Replied by pete kelly on topic Cigar Lighter
As I understand it the '36 lighter does not pop out; only the '37 is pop out.
Correct me if I am wrong; it wont be the first time!
Pete
Pete
- Thank you received: 135
30 Nov 2022 15:35 #46496
Replied by 1748 S on topic Cigar Lighter
I would guess the driver could tell when it was heated when the cat eye glows. Thats what the cat eye was for?
Mike I believe you are correct. But is the lighter supposed to be pressed in and it stays in till the element is hot enough.Then it pops out all on its own.
30 Nov 2022 15:35 #46495
30 Nov 2022 04:37 #46494
- Thank you received: 305
29 Nov 2022 04:49 #46487
Replied by Terry Cockerell on topic Cigar Lighter
Don't worry about it working ................ give up smoking!
Actually I was just wondering the same thing a few minutes ago while fixing a few things up in the dash board area.
Compare the lighter to a modern one. I would assume for 1936 the driver held the lighter in until it became heated.
29 Nov 2022 03:51 #46486
Cigar Lighter was created by 1748 S
I have an original cigar lighter and the dash housing I purchased a few years ago from Felix at the ACD factory in Oklahoma. How does it work? When I push it in is the design so it stays in till the element heats up. Then pops out. I understand the glowing part of it. Just not sure if I have to hold it in till it glows. Thanks...
