- Thank you received: 305
Hood Prop Upper Connection To Hood
28 Jan 2023 04:38 #46727
Replied by Terry Cockerell on topic Hood Prop Upper Connection To Hood
Thanks Guys, mine had been in the down position for many years and I guess it is the same with a of of Cords. The second picture in the first posting was taken in Auburn in 2011.
The picture with the bracket in the up position was the Award Winning Westchester of Mark Clayton.
- Thank you received: 219
28 Jan 2023 02:31 #46726
Replied by JIM.OBRIEN on topic Hood Prop Upper Connection To Hood
EL is correct - the rivet should be up. If you put the rivet down the hood will open wider but the prop doesn't sit right when the hood is closed.
- E L
- Thank you received: 25
28 Jan 2023 02:31 #46725
by E L
Replied by E L on topic Hood Prop Upper Connection To Hood
Almost every car that I have looked at with the rivet below has a scratch under the hood at the hinge point, especially the supercharged ones. Moving the rivet up into the hood eliminates that.
27 Jan 2023 22:19 - 28 Jan 2023 00:26 #46724
What evidence do you have to support your statement? Comment from others would also be appreciated especially the Judges.
I found a picture of one of the Hand Built Cords which I tried to attached. The rivet can clearly be seen below the hood louver.
I will take a photo of this picture and try attaching it.
Last edit: 28 Jan 2023 00:26 by Terry Cockerell. Reason: Revising text and adding picture
- E L
27 Jan 2023 10:53 #46723
by E L
The first pic with the rivet inside the hood.
27 Jan 2023 07:09 - 27 Jan 2023 07:11 #46722
Hood Prop Upper Connection To Hood was created by Terry Cockerell
Looking through pictures to determine what is the correct or Factory way things were put together I recently noticed there are variations in the attachment of the hood prop at the top. Attached are pictures of the two versions.
One has the mounting bracket above the hood louver.
The other has the bracket below the louver.
What is the correct way to attach the hood prop?
Last edit: 27 Jan 2023 07:11 by Terry Cockerell. Reason: Revising Text
