- Thank you received: 44
Philco Style Antenna
- wynlaidig
30 Mar 2023 02:06 #47036
by wynlaidig
Replied by wynlaidig on topic Philco Style Antenna
I am still looking for photos or a diagram / print of the later style antenna, if anyone has a car with this style antenna on it. This is the version that mounts with two U shaped brackets and has wires running back and forth between the brackets. (Not the more-common flat antenna with three galvanized straps)
- xjn001
25 Mar 2023 19:54 - 25 Mar 2023 19:59 #47024
by xjn001
Replied by xjn001 on topic Philco Style Antenna
See your private message Wyn Laidig
R.Stevens
R.Stevens
Last edit: 25 Mar 2023 19:59 by xjn001.
25 Mar 2023 16:15 #47020
by pete kelly
Replied by pete kelly on topic Philco Style Antenna
hi Wyn
Send me a pic of the front of the box.
Pete
Pete
- wynlaidig
25 Mar 2023 14:39 - 25 Mar 2023 14:41 #47017
by wynlaidig
Thank you Terry! I mean't Philco! (I have a couple old Zenith radios that I have restored and that brand name just slipped out accidentally.) I have a Westchester sedan that originally came with a Philco radio and with the later style antenna (antenna mounting brackets pictured above). I am missing the nameplate on the front of the Philco radio box, and also need to fabricate the correct original-style antenna that came with car. Hence my two posts looking for these two bits of information.
Last edit: 25 Mar 2023 14:41 by wynlaidig.
24 Mar 2023 21:41 #47011
Replied by Terry Cockerell on topic Philco Style Antenna
Wyn in your latest posting you mentioned a Zenith Radio.
The only radios that I was aware that were used were Crosley and Philco.
- wynlaidig
24 Mar 2023 21:21 #47009
by wynlaidig
No, the antennas are totally different, and mount quite differently as well. The U-shaped brackets in the photo of my initial post bolted to the underside of the car, and had wires attached on insulators. But that's all I know.
24 Mar 2023 00:18 - 24 Mar 2023 00:39 #46998
Replied by JIM.OBRIEN on topic Philco Style Antenna
Hi Wyn,
I think the antennas were the same - I may be wrong since I have mainly worked on the earlier Cords and never really studied the antennas. Below is a photo of the antenna. The brackets you show are the brackets that hold the antenna in place. I can take photos of them on a car if you need it. The antenna is run between them with insulators and hook type fastners - sorry I think mine are buried right now. The triangular end is towards the front and the lead wire is attached with a screw and nut.
Last edit: 24 Mar 2023 00:39 by JIM.OBRIEN.
22 Mar 2023 19:45 #46985
Replied by 1748 S on topic Philco Style Antenna
Wyn, My Cord did not come with any type of antenna under the car. I have not been under my car in probably 45 years... And thats a shame to admit. I will get there. I will be watching this post too. My 37 was made in the first or second week of January 1937 ...
- wynlaidig
22 Mar 2023 16:55 #46984
by wynlaidig
Philco Style Antenna was created by wynlaidig
Does anyone have photos, or better yet, plans for the later style antenna used with Philco radios? I know it was mounted with brackets like the ones shown below and I assume it had wires going back and forth between the brackets, but this photo is all I have been able to get so far. I need buy or fabricate this type of antenna but need all the measurements.
