Dual Master Cylinder Options?
- rg171352
06 May 2023 01:23 #47156
by rg171352
Replied by rg171352 on topic Dual Master Cylinder Options?
Then you very much for your replies.
03 May 2023 23:22 #47154
Replied by Terry Cockerell on topic Dual Master Cylinder Options?
From memory Tom Parkinson used a modern two stage master cylinder.
He is not listed in the current Directory
- Pat Leahy
- Thank you received: 27
03 May 2023 18:18 - 03 May 2023 18:23 #47152
by Pat Leahy
Pat Leahy
Replied by Pat Leahy on topic Dual Master Cylinder Options?
On the 812 Cord I am presently working on, I plan on using this Ford model A conversion master cylinder. Looks like it mounts the same as a Cord.
Ford 91a-2140 Master Cylinder Upgrade 3 Bolt Dual Reservoir 1939-48 Pas 48-52 F1
Ebay listing
Ebay listing
Pat Leahy
Last edit: 03 May 2023 18:23 by Pat Leahy.
03 May 2023 17:16 #47150
Replied by 1748 S on topic Dual Master Cylinder Options?
use the seasrch item here. Some time back a member posted how he made this conversion. I do not recall how it worked out.
- rg171352
03 May 2023 15:47 #47149
by rg171352
Dual Master Cylinder Options? was created by rg171352
Has anyone converted their car to a dual master cylinder setup for the brakes? If so: How did you make it work? What parts did you use? Were you happy with the results?
