Rear Door Spring ................. Replacements
26 May 2023 07:10 #47248
Replied by Terry Cockerell on topic Rear Door Spring ................. Replacements
After waiting over a week for the 1936 Ford door springs to arrive, I discovered I could not use then as they were coil bound when fitted.Consequently I have used the larger spring from the 1939 lock.
22 May 2023 06:13 #47241
I have discovered that Ford door locks from the 1930s are identical to those used in the Cord. The attached pictures show my rear door lock assembly together with a 1939 Ford door lock. The only real difference is in the spring.
The 1936 Ford door lock springs are the same as those used in the Cord 810
If you look closely at the last picture the Lock appears to have been made in England.
I would have thought Ford had their own unique design.
17 May 2023 11:36 #47220
by pete kelly
Replied by pete kelly on topic Rear Door Spring ................. Replacements
17 May 2023 06:32 #47219
AC Parts is not responding to emails. It is very difficult to contact Stan.
I think I have a solution in the form of a door lock spring from a 1936 Ford.
I am waiting for them to arrive and will post what transpires.
- wynlaidig
- Thank you received: 44
16 May 2023 17:20 #47216
by wynlaidig
Replied by wynlaidig on topic Rear Door Spring ................. Replacements
I think you can order these from Stan Gililand.
06 May 2023 06:22 #47159
Rear Door Spring ................. Replacements was created by Terry Cockerell
One of the rear door springs broke. I am looking for a suitable replacement.
Early Ford door springs look similar.
Can anybody suggest a suitable replacement?
