Clutch setup? jerks with the engine
- RKF
It turned out to be the Transmission mount bolts where loose
- pac32
- Thank you received: 219
- Stanislav1989
- Thank you received: 305
CORDially MIke
- Stanislav1989
- Stanislav1989
What specs were the clutch rebuilt to? The Cord uses a Long 10CF clutch. This clutch was also used in a Ford trucks and some other cars but was built to different spec.s. What is your email and I'll send you how to set up the clutch.
You also mention the pressure plate was straightened. That raises a lot of questions, How did it get warped to begin with? Was it ground back to proper straightness? Were all hard spots removed?
Have you checked the engine and transmission mounts? Also the CV joints. They would also cause similar problems.
- Thank you received: 135
- rhauser
Robert L Hauser
- Stanislav1989
I have already been given excellent advice on the forum.
I wanted to ask if you have information about the car's clutch. currently our clutch jerks with the engine and jumps a lot before it catches. we have a newly lined clutch, overall it has undergone a renovation and straightening of the pressure plate and it still jumps. We are at a loss and we don't know what it could be because we don't have any exact values for the clutch setting. if there is such a thing.
thank you very much for the advice
Stanislav
