Whooping Noise When Turning Right
- ShanghaiJack
30 Jul 2023 08:42 #47486
by ShanghaiJack
Replied by ShanghaiJack on topic Whooping Noise When Turning Right
Thank you very much!
I appreciate your reply,
and I'll contact Pat regarding
these upgrades.
these upgrades.
30 Jul 2023 00:21 - 30 Jul 2023 01:53 #47484
Replied by Terry Cockerell on topic Whooping Noise When Turning Right
It could be a number of things in the drive line to the wheel. The original CV joints do wear a lot, the wheel bearing could have failed or is loose in the housing, you could also have a wheel that is loose even when the wheel bolts are done up tight.
Pat Leahy in Indiana has made modern drive shaft assemblies that eliminate most of the problems. His email address is ............ [email protected]
I have not seen any of these but would recommend talking with Pat.
Last edit: 30 Jul 2023 01:53 by Terry Cockerell. Reason: Revising text
The following user(s) said Thank You: ShanghaiJack
- ShanghaiJack
29 Jul 2023 01:30 #47476
by ShanghaiJack
Whooping Noise When Turning Right was created by ShanghaiJack
I'm a newly minted 812 owner, and my Cord
makes a strange metallic whooping noise
when turning to the right.
Where do I begin at trouble-shooting the issue?
All replies, and wisdom shared, would be most appreciated.
