- Thank you received: 305
Main cylinder flow restrictor availability
27 Sep 2023 02:52 - 27 Sep 2023 04:54 #47792
Replied by Terry Cockerell on topic Main cylinder flow restrictor availability
Adam they are easy to make if you have a pedestal drill and maybe a bench lathe.
You must be a new member as you are not listed in the 2021 - 2022 Directory.
My email address is [email protected]
Last edit: 27 Sep 2023 04:54 by Terry Cockerell. Reason: Revising Text
26 Sep 2023 20:29 #47791
by pete kelly
Replied by pete kelly on topic Main cylinder flow restrictor availability
I got mine direct from Geo Arakelion ACD Club member from Michigan
- LumsdenLive
26 Sep 2023 18:22 #47790
by LumsdenLive
Adam Lumsden
1936 Cord 810 Westchester 1710A
Main cylinder flow restrictor availability was created by LumsdenLive
I've seen mention of flow restrictors designed by George Arakelian to slow down the main cylinder but have not been able to locate any drawings or instructions. Is anyone in the club making these?
Adam Lumsden
