shifting problems
I'd really like specs and source on the electric wiper motors. Thanks.
- Thank you received: 136
Probably after the Convoy. Right now we all have to stay focused on the August goal!
- Red Fred
I was able to dig that issue out straight away (I've actually been a member for many years). I got lucky however, and managed to get the car shifting perfectly today, despite the pouring rain here in SF. I have no clue as to what got the juices flowing (a shame really), but all I did was to constantly take things apart, and re-assemble them.
I even got to test my new 6v electric wipers today. I drove the car long enough today to get the nerve to re-install the trans cover & front bumper!
Thanks again to all who chimed in. Hopefully she's cured now.
RF.
Life Member
Henry Portz is our club's Cord Technician and you should definitely consult him. He wrote a multi-page article in the Newsletter on checking out the electrical system. It appeared in issue 2003-7. There was an additional note by Henry in 2005-5, page 14.
Let me know if you don't have these issues.
- Red Fred
Can anyone verify if the white #1 is indeed energized by #5 at the selector switch?
Life Member
- oldbanger71
Vaco has prooved that the reproduced switch and cut harness can be made to be riliable with little more effort than just cheap crimp connections ( he used good quality gold connectors from RC Models ) so Vaco is also a very good source for well tested information. ( i hope, he's fine, with naming him here ) <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
812 310 121 S
- Red Fred
1748 S wrote: Hello Red. I'm really not that up on what your refering to on these shifting issues. My thoughts are you have some cross over voltage causing this problem. What age is your wiring harness. You being knowledgeable in the electrical field helps plenty. Did you replace any switch before this issue started happening. I'm not going to say start throwing parts at it till you fix it either. I'm thinking Henry Portz is the member you really need to talk with on this electrical issue. I have been planning to drive up to his location so I can buy some of his wiring harness's he makes. So if anyone knows these shifting issues he would. I have noticed this site is really slow for getting an answer to questions asked. I have been reading lots here since joining up again. I had forgotten that I was a member back in 2005.
I believe the harness was from Rhode Island Wiring some years ago (probably 10-12 years). It seemed to have been working fine, along with all my original switches until now. I've only really started using the car these last few months however.
Thanks, RF.
Life Member
- Red Fred
I get a chatter, or rapid back & forth motion of the left/right cross shaft with the clutch pedal depressed. I fault this to the white (#1)wire which is returning back to the interlock switch at the front of the trans. This white (#1) gets energized from the Green/red (#5) wire when in the Neutral position. The white (#1) us in common with the green (#2), and red/green (#4) when the interlock switch in neutral, thus sending voltage to both contact of the cross shaft. All my info says that 2,4,&1 should be in common during Neutral, at the interlock switch, and have NO voltage. I don't understand how this can happen according to the schematic.
Is it true that the White (#1) gets energized from the green/red (#5) in the selector on the Coloumn during Neutral?
Almost hairless, RF.
Life Member
- Red Fred
I arrived home too late to really get in and use your desciptions today. I'm wondering how one goes about testing the solenoids with the vacume guage/pump? Do I carefully undo the vacume line at the cross shifter, and test from that end of the line? How much vacume should I expect? I've never used a vacume pump, but I managed to borrow one.
Many, many thanks, RF.
Life Member
- Dan DiTullio
It sounds like you either are not getting voltage to the crosshift solenoid (terminal # Black wire. Or perhaps there is a vacuum leak where the solenoid mounts to the housing. A vacuum pump with a gauge is most helpful in diagnosing this.
Here below is a bit of information that I put together and refer to from time to time.
Cord Shift System function
(Clutch depressed)
Neutral The shift selector switch receives power from Red(10) wire to Yel/Blk(3) to interlock switch. Interlock switch Yel/Blk(3) to Grn/Red(5) should have 6 volts.
Interlock switch connections between Wht(1) to Grn(2) to Red/Grn(4) no voltage.
1st The shift selector switch receives power from Red(10) wire to Grn(2) and Blk(. Blk( supplies the crosshift solenoid ® . After the crosshift solenoid moves, the interlock switch connects the power from the Grn(2) to the Grn/Red(5) wire. The Grn/Red(5) supplies power back up to the selector switch wafer to the Blue(6) wire. The Blue(6) wire supplies the solenoid ? to pull the main shift cylinder into 1st gear.
Interlock switch connections between Wht(1) to Yel/Blk(3) to Red/Grn(4) no voltage.
2nd The shift selector switch receives power from Red(10) wire to Yel/Blk(3) to the interlock switch. Interlock switch Yel/Blk(3) to Grn/Red(5) supplies power back up to the selector switch wafer to the Brn(7) wire. The Brn (7) wire supplies the solenoid to pull the main shift cylinder into 2nd gear.
3rd The shift selector switch receives power from Red (10) wire to Yel/Blk (3) to the interlock switch. Interlock switch Yel/Blk (3) to Grn/Red (5) supplies power back up to the selector switch wafer to the Blue (6) wire. The Blue (6) wire supplies the solenoid ? to pull the main shift cylinder into 3rd gear.
Rev The shift selector switch receives power from Red (10) wire to Grn (2) and Blk (. Blk ( supplies the crosshift solenoid ®. After the crosshift solenoid moves, the interlock switch connects the power from the Grn (2) to the Grn/Red (5) wire. The Grn/Red (5) supplies power back up to the selector switch wafer to the Brn (7) wire. The Brn (7) wire supplies the solenoid to pull the main shift cylinder into Rev gear.
Interlock switch connections between Wht (1) to Yel/Blk (3) to Red/Grn (4) no voltage.
4th The shift selector switch receives power from Red(10) wire to Red/Grn(4) and Yel(9). Yel(9) supplies the crosshift solenoid . After the crosshift solenoid moves, the interlock switch connects the power from the Red/Grn (4) to the Grn/Red (5) wire. The Grn/Red (5) supplies power back up to the selector switch wafer to the Brn (7) wire. The Brn (7) wire supplies the solenoid to pull the main shift cylinder into 4th gear.
Interlock switch connections between Wht (1) to Grn (2) to Yel/Blk (3) no voltage.
Hope this helps,
Dan DiTullio
- Red Fred
So I attempted to adjust the clutch linkage to get even further throw (and more clutch/flywheel separation), and then adjust my clutch switch for activation closer to the floor of the pedal travel. All well & good.
However, upon attempting to road test this new adjustment, I can't get 1st or reverse now! The cross shaft refuses to go over to the left side, where 1st & Reverse are then selected. In fact, the cross shaft chatters back & forth when in Neutral, and the clutch depressed.
I have taken apart the interlock switch, and re-located the critical contact that was slightly worn. The switch checks out electrically. The neutral switch checks out electrically also.
When I try and do the recommended electrical tests on the interlock switch, it rings out fine with the shifting harness disconnected (I have the central splice barrel). However, with the harness connected to the shifter, it does NOT ring out correctly. I've also tried to ring out the shifter from this splice barrel, and it seems OK.
Any suggestions or advice? With the car running, clutch pedal held down, shifter in 1st or Reverse; the gear will engage, ONLY if I manually move the shifter on the cross shaft.
Many Thanks, RF.
If I do need a new inter-lock switch, is there a source? I don't think my folding tabs will take another un-doing!
Life Member
