Radio
18 Aug 2011 18:55 #20760
by Tom Georgeson
Replied by Tom Georgeson on topic radio
You are right. I don't know how I came up with that address.
- charlesflick
18 Aug 2011 17:25 #20759
by charlesflick
Charles Flick
Replied by charlesflick on topic Radio
Charles Flick
18 Aug 2011 04:57 #20757
by Tom Georgeson
After I posted my comment I looked at Josh's note and realized that he didn't give a phone number. The number is 800-933-4926 and I talked to Matthew. My radio was in my 1936 Westcheter. Matthew told me it was solid state 6 volt Positive with an O base. Their web site is
www.radio.com
18 Aug 2011 04:46 #20756
by Tom Georgeson
This a is a speciality item. There is no part number. You will just have to contact the above people and see if they will make you one. It took me about five months to get mine.
- Emporator
18 Aug 2011 01:01 #20755
by Emporator
Replied by Emporator on topic Radio
Does anyone have the part number for the solid state vibrator that would replace the mechanical one in a Crosley unit?
17 Aug 2011 11:05 #20751
by Josh Malks
Replied by Josh Malks on topic Radio
One step in making the radio work would be replacing the mechanical vibrator with a solid state one. Available from Antique Automobile Radio folks in FL. No hum, much less current draw.
- Thank you received: 136
16 Aug 2011 23:43 #20746
Replied by 1748 S on topic Radio
If you need a vibrater for either radio I have a box full of them. Just let me know what the numbers are and what type maker your radio is....
16 Aug 2011 23:16 #20745
by
Replied by on topic Radio
Hi Dennis,
Cord used two different makes of radios. A Crosley and a Philco.
The top and bottom should have a screw in the middle. Remove the screw and the top or bottom should be able to be pulled off. If you need the schematics for the radio let me know and I'll email them to you.
Note the light on the dash is in the head and will have nothing to do with the radio working.
16 Aug 2011 13:22 #20743
by
Replied by on topic radio
Dennis there are still plenty of stations for A M, but you can get the radio redone to run AM or FM .
K Clark
K Clark
- Dennis Jolicoeur
16 Aug 2011 00:50 #20739
by Dennis Jolicoeur
Dennis Jolicoeur
Radio was created by Dennis Jolicoeur
Does anyone know much about radios in Cord sedans? I am trying to finish up a few things on my Cord before Auburn. I have owned the Cord for a little over three years and the Radio has never worked the light comes on in the dash when I turn it on. I tried to open the case up under the dash so I could take a look and see if it is the vibratory but I can?t seem to find a way to open it, has anyone got an idea? It has a small round emblem that say Cord in it. I have not been able to a diagram of it. I know even if I get it to work I won?t be able to get many stations on it anyway.
Dennis Jolicoeur
