- Thank you received: 16
810/812 door handle clips?
- alsancle
29 Sep 2012 15:33 #23675
by alsancle
Replied by alsancle on topic 810/812 door handle clips?
- Pat Leahy
- Thank you received: 28
30 Jul 2012 16:40 #23223
by Pat Leahy
Pat Leahy
Replied by Pat Leahy on topic Door clips
This was a repair I came up with when I began restoring my first Cord. This clip was used on most General Motors cars in the sixties and early seventies. It is used to hold the door lock in place.
Pat Leahy
- hportz
28 Jul 2012 06:48 #23217
by hportz
www.portzcordz.com (photos)
Replied by hportz on topic Handle clip
A.J. The article you need is in Tech Talk , 2002 #7 ,page 14 . It mentions
a 1968 Camaro but no part #.
- alsancle
23 Jul 2012 21:46 #23199
by alsancle
Thanks! I'll try to dig that up on the CD.
23 Jul 2012 18:11 #23194
by
Replied by on topic 810/812 door handle clips?
Somewhere buried in past newsletters is a suggestion for using a GM door handle retention clip. It is U shaped and passes through a slot in the door to engage with slots in the inner-projecting portion of the handle. You do need to cut the slots. I believe a Camaro part number was given.
- alsancle
22 Jul 2012 11:05 #23186
by alsancle
810/812 door handle clips? was created by alsancle
Is anyone reproducing the spring loaded clips which keep the exterior door handles in the door? I need them for a conv but I assume the sedans are the same. Does not seem like the greatest design in the world.
