Cord Wheels and Radials
Incidentally, if you like the look of blackwalls on your Cord or Auburn, 215R75-16 radials from any tire store will work just as well at half the price!
225/75 R 16 // 6:50x16
Miranda - Yokahoma
3 1/2 WW for $249
See page 23
www.dbtires.com/2012_catalog/2012catalog_Hi.pdf
- Mike Markin
- oldbanger71
812 310 121 S
- twinx1649
I thought Moonshadow looked great with the aluminum wheels; and no, I didn't notice the offset. That said, I would rather be safe than sorry and double check the fit first. Don was more than accommodating with his offer to send me a wheel to test fit. Fortunately, I'm at the right stage in the restoration to make any modifications to the fender wheel openings before paint.
Don also mentioned that the aluminum wheels should be used with the Richardson joints/hubs and heavy duty rear drums. The idea being that the wheel/hub assembly would not be stiff enough if you didn't go all-in. I need to spend some time reading up on this one since wheel fatigue life may be compromised with weak, or cracked hubs. Does Moonshadow have the Richardson joints and HD rear drums?
Anyway, since low unsprung mass is important to ride quality I'm glad aluminum wheels are available.
Jim McCarthy
Fenton, Mi.
ACD Life Member
- twinx1649
There is a great deal of info out there regarding Cord wheel and tire options. I'm in the process of making that same decision too. While at Auburn this year, I had a chance to talk to a number of members who recommended Diamond Back over Coker for a number of reasons. I've also been considering aluminum wheels, but want to mount one with the Diamondback to make sure the additional 1/2" offset isn't noticeable. I also noted that the rear fender opening does get closer to the tire and the lower edge of the fender may need a tweak for needed clearance.
Another good source of wheel info can be found in the following ACD Newsletters:
Volume LVI . Number 3. 2008 Page 14
Volume LVI. Number 6 . 2008 Page 8
Volume LVIII . Number 4 . 2010 Page 8
Recommended tire: HANKOOK Diamond Back, Size 215-75R16
Jim McCarthy
Fenton, Mi.
ACD Life Member
- Bill McLaughlin
I have run a set of Black Diamond radials with tubes on what I understand to be the heavy duty Cord wheel, for several years.
Bill McLaughlin
- Mike Markin
- Tim Gilmartin
- Thank you received: 57
I did the ccca caravan in montana in 2008 (1000miles), the cord convoy last year (1450 miles), and just finished the ccca nordic trek caravan last month (750 miles). I must be over 4000 miles total on them. The car runs straight down the road, and the tires hold the pressure.
Cordially, tim.
- Pat Leahy
- Thank you received: 28
Pat Leahy
- Mike Markin
