Front spring suspension bolts
04 Oct 2012 03:57 #23697
by Josh Malks
Replied by Josh Malks on topic Front spring suspension bolts
Just as important is the diameter. The original bolts "necked down" to a smaller diameter between the ends, which were a larger diameter to fit the steel cups. I think the two diameters were 3/4" and 1/2". The replacement bolts, like Henry's, are 3/4" along their entire length.
- Thank you received: 135
03 Oct 2012 21:51 #23695
Replied by 1748 S on topic Front spring suspension bolts
Go to Henry Portz web site. See the suspension bolts he offers. Much better than what the factory had to offer because of the metal they used 70 years ago...
- E L
- Thank you received: 25
03 Oct 2012 20:01 #23694
by E L
Replied by E L on topic Front spring suspension bolts
Probably the saftey loops which "restrain" the spring from dragging on the pavement
- charlesflick
03 Oct 2012 12:57 #23691
by charlesflick
Charles Flick
Replied by charlesflick on topic Front spring suspension bolts
" I had the restrainers fitted. "
What "restrainer"?
What "restrainer"?
Charles Flick
02 Oct 2012 04:12 #23687
Henry Portz makes a good quality bolt for this area of use.
01 Oct 2012 00:05 #23683
by Tom_Parkinson
Replied by Tom_Parkinson on topic Front spring suspension bolts
Hi,
No need to re-invent the wheel. Call Stan at Auburn Cord Parts in Wellington, KS, for modern, and stronger, replacements.
- Barrie Sly
30 Sep 2012 23:42 #23682
by Barrie Sly
Front spring suspension bolts was created by Barrie Sly
I have just had one of the front spring suspension rods snap,lucky I had the restrainers fitted.
I will make a new pair of bolts but I need to know the correct grade of steel,can anybody help?
