Cracked block
- Curtis Bartell
"I've cut it twice and it's still too short."
- pac32
Thanks for attaching the pictures of the Cord block. My crack is along the top, just at I thought by looking at your pictures, the crack runs along the bottom of the deck for about 10 inches. One thing your pictures show is how thick the casting is in that area, looks like plenty to stitch. I am now somewhat on the fence as to stitch it or first try a stop leak in it. At this point it is only just a slow weep and I have not added ant coolant to it, the car has now traveled about 170 miles.
Jon
- Mark Tomei
If you have a chance, take a look at the block crack repair video on the Stitch-N-Lock website. It will give you a better feel of just what an elegant repair solution this can be. Their method is slightly different than the one shown here but, the overall concept is identical.
- silverghost
What a fantastic block repair ~~~
This has to be one of the most complicated, & best block casting repairs, I have ever seen !
In your photos am I also seeing two badly cracked center cylinder barrel castings in that same block ?
If so~~~
How were these cracked cylnders repaired ?
Were new cylinder sleeve liners just pressed in after boring the diameter slightly oversize in the cylinder casting bore; and the cracks just left as seen ?
Were the cracks brazed ?
Or~~~
Did you use some other crack repair method in this cylinder wall area ?
Thank's
BRAD~
- Mark Tomei
Here is a bit more detail; The area is first prepped by magna-fluxing the affect zone to determine the extent of the cracking or fractures. If you look at the second picture, you will see a red outline which was drawn at the farthest extent of the damage. The next step was to use a cutting wheel to open up the square back to virgin unaffected material. The next step was to find a piece of compatible patch material for the block since the original was on lost in 1946 on Route 66 somewhere. In my case, I was lucky enough to have had a steel plate that was made up by the Cord genius, the late Jim Howell. Jim had made up large cast plates which even included the nipple for the drain petcock. This plate was then scribed exactly to fit my prepared window almost on an interference basis. The next job was to drill a hole at the center of the seam and begin the process of drilling and overlapping pins made of the same material as the patch/block to eventually follow the complete outline of the plate seam. As EL said, it's not a job you can do leaning over a fender upside down. It has to be done while the engine is apart and in a very stable stand. The more time you take, the better the repair will look in the end. All in all, it is the perfect fix for engine blocks that don't do well being rapidly heated and cooled in the welding process. So many of these blocks were scrapped after improper fixes or just because they appeared to be hopelessly broken. This process does present a practical second chance. I hope this helps.
- T_Hussey
Mark, once the block was prepared, was "donor" metal inserted then drilled and stitched? Perhaps you could comment a bit more on how this was done. I can't even detect that stitching was done from the photo.
Cheers,
Tom Hussey
I stand in awe of this repair. I have to admit, if the block in my 810 were similarly cracked, I would have been considering a modern engine/drivetrain swap.
Thank you for showing what can be done with proper technology and drive.
- auburnandyscar
Check out my build at:
www.1932auburnsedan.com
- Mark Tomei
Here is a supercharged block that was damaged years ago by frost. You can see the first picture showing the damage that the break was fairly major but contained in the open area of the water jacket. The second picture shows the prep we did to square up the hole and lastly, the newly "stitched" area after grinding and rotary filing. It's an incredible process that is water tight by design and can be cosmetically undetectable. Be prepared for a $1,500 to $2,000 bill for a repair of this size if you send it out to a qualified shop. With SC blocks being virtually unavailable, those sorts of numbers will eventually seem quite reasonable. This particular block was sent out after to be Wheelabrated and then went on to a .030 over rebuild and balancing that should last well into the next millennium.
M
- Bill Hummel
pac32 wrote: Are there any manuals out there that tell how to remove the engine and transaxel? I am especially interested in information on how to disconnect the front axels from the unit.
You should have been in Auburn this year to see the process live. You could have watched my Phaeton engine pulled in less than 90-minutes.
George Arakelian just had my engine block repaired by stictching. Where it was too hard to be drilled, they soldered in bronze I believe. The block was then pressured up and it is just fine.
- silverghost
See my various crack repair discussions on your other Cord forum thread & posting.
Thank's
- pac32
It?s people like you that have a wealth of knowledge to share that keep the cars on the road.
Jon
- hportz
hood hinges & an easy way to align the hood when reinstalling it . It also helps to make four alignment studs from matching threaded stock about 1 1/4"long with a screwdriver slot on one end . The studs can be placed
in the hood before it is set on the car & then used to align with the hinges.
Then lift the hinge, install nuts & then tighten after aligning the hood.
Remove the studs one at a time & replace with the screws & lock washers.
Replace the boxes. Works for me. Henry
OOPS, I slipped! The hinge drain boxes also need to be removed , sorry
about that! H
www.portzcordz.com (photos)
- pac32
I ordered from ACD club the Transmission manual and from ACD museum the service manual today.
My plan is still to pull the engine and let a professional repair the crack, don?t wont to mess up a cord engine block.
Is there a secret on removing the hood on a 812? Or do I have to crawl under and undo the 4 bolts?
I am not very happy with the outfit that sold me the car, without disclosing this problem. This was probably the reason the owner brokered the car, lucky me.
Jon
- xjn001
- oldbanger71
812 310 121 S
- Mike Brady
I would follow EL's advice.
- E L
- Thank you received: 25
I don't think it can be done in the car.
Also, I. ran into a problem where the block is so hard in some areas that drilling is impossible.This hardness is most likely due to improper cooling of the block during the casting process
- Mike Brady
From the following link, you will find the Cord Transmission manual. It contains some valuable information including some disassembly information.
www.shop.phpstack-1081784-3880776.cloudwaysapps.com/category.sc ... egoryId=10
A right angle drill might also help with your repair task as well as removing the fender and fender apron.
- pac32
I would appreciate any suggestions as to what service manuals I could buy that would be helpful in this project.
Jon
- Mike Brady
I've never tried this, it's just a thought.
- pac32
If I figure out how to do it I will post a picture of the crack.
Any leads would be greatly appreciated.
Jon
