- Thank you received: 135
Water Pump, how to remove the cover
- ETHAN ALLEN TURNER
I [u:se9ad1qd]really[/u:se9ad1qd] like the idea of tapping the three unassigned holes in the cover to ease possible future removal. I have had occasions to remove sheaves from shafts after they had been there since the 50's. Thankfully, pulley-type designers had built in tapped holes for pusher bolts. Ditto, btw, for brake drums and rotors on modern cars and light trucks.
The techinque is less of a push-em-off motion than it is a tighten-to-create-strain concept. You then bonk the part to be moved with a BFH to shock the metal-to-metal surfaces. That way the threads do not strip out. Repeat as necessary.
In working with orphan cars my entire adult life I have always re-assembled parts with the thought of maybe having to take them apart in 25 years. (Learned that from my Dad.) As I have kept the Cord, the LaSalle, and the Buick that long, I have reaped the harvest of those decisions a number of times.
Congratulations on successfully getting your unit apart! Please keep us advised as to how the repair ends up.
- Aris Loumidis
After two days with Coke poured in, today I got down to it. I first used the Dremel to clear a path around the cover, then inspired by Mario von Allmen's suggestion to hammer a sharp knife in there, I used hacksaw blades, well-sharpened on one end.
They can take some good hammering and I first managed to insert one, then two, then three of them, in three different places around the cover, see pics below
With lots of heating it eventually moved!. In my pump, the cover itself was stuck allright, but what made the job more difficult was the ball bearing which was frozen on the shaft. Apparently when the seal started leaking and because the drain hole was plugged up, the water got into the bearing and destroyed it freezing it inplace as well.
Now I'm on to making the seating tool, even though I still don't get what is an 'open coat abrasive'; is it a paste or sanding paper? Any explanation will be appreciated.
Also has anyone tried drilling and tapping the three holes on the cover for 'jacking-off' the cover when it's next needed? (hopefully not in my time..)
Here are the pics with the hacksaws in place.
Aris Loumidis
Athens, Greece
ACD Life Member
______________
1936 CORD 810 Phaeton
- silverghost
Use liquid wrench, or similar penetrating oil to help penetrate the rust seam after heating.
The heat will suck-in the penetrating oil by capillary action.
Keep repeating the Heat-up & cool-down cycles while putting more penetrating oil on the rusted & corroded gasket seam.
Heat will work small wonders in breaking loose almost all old frozen parts !
Too bad these covers weren't Never-Seez'ed when assembled way back then.
In the 60's, my father, a first class machinist, rebuilt the 812's water pump. I don't know if he ended up breaking the original cover. If so, he would have made a new cover for it. He did say that it was the hardest part of the entire car's drive train rebuild. I'll look and see just what he did.
I don't know how he got it apart, but I'll bet your life that I know how it was reassembled: with Never-Seez !
Frankly, I can't say I have had success with this method, but this was the advice of an old time Cord man from in the '40's whose approach was to save every part if at all possible..
- xjn001
- Aris Loumidis
Your detailed 1988 article is since then in my bibliography, Im particulary looking for the best way to pry open the cover, with minimal damage. Besides bathing it in Coke, I'm now thinking of pressing the shaft from the back end outwards, hoping that will do it. Chances are that it will destroy the old seal and the bearing, which is anyway busted. I was looking for any more ideas even on how to break the cover if need be.
Aris Loumidis
Athens, Greece
ACD Life Member
______________
There is an article in the newsletter that I wrote, using material provided by JK Howell and Henry Portz, many years ago. If you have the ACD club archive DVD you should be able to find it quickly. You need to follow the instructions.
- Aris Loumidis
Back working on the 810 again, and on my leaking water pump. I'm trying to remove the cover, with no luck so far. Lots of WD40 for some days and today I even poured in some Coke and pray it won't damage the impeller and shaft.
Any other ideas ???
Happy, Healthy and Prosperous holidays to everyone !
Aris Loumidis
Athens, Greece
ACD Life Member
______________
