- Thank you received: 27
810-12 Cord instrument light rheostat availability
- Pat Leahy
12 Mar 2013 11:47 #24772
by Pat Leahy
Pat Leahy
Replied by Pat Leahy on topic 810-12 Cord instrument light rheostat availability
I have modern replacements available at $10.00 each + shipping. The new style does not have a fully off position and should be wired into the headlight switch to function only with the headlights or park lights.
Pat Leahy
12 Mar 2013 10:00 #24771
by Josh Malks
Replied by Josh Malks on topic 810-12 Cord instrument light rheostat availability
Check your ACD Newsletter Archive DVD. There is a decades-old article by Syd Ayres on fitting a "modern" rheostat to the Cord quadrant.
Also, if you have one that works but flickers, try contact cleaners like No-Ox or NeverStall. (Google them.)
- oldbanger71
12 Mar 2013 09:42 #24770
by oldbanger71
812 310 121 S
Replied by oldbanger71 on topic 810-12 Cord instrument light rheostat availability
Peter, do you need instrument-panel-lights ? What type of bulb and socket is fitted now, i might be able to organize something, as i get bulbs directly from the factory.
www.pst-ch.ch/oldtimer/birnen.html
This is only a small selection and if you let me know what you need, i can tell you what i can arrange.
For the Reostat have a look here: dech.rs-online.com/web/p/regelwi ... e/0149085/
Best regards, Philipp
812 310 121 S
- silverghost
12 Mar 2013 03:56 #24769
by silverghost
Replied by silverghost on topic 810-12 Cord instrument light rheostat availability
Possibly could the rheostat's wiper arm's rotating contact spring pressure be increased by slightly bending it to put more working pressure on the resistor coil ? Heat from the resistor usually slowly warps the rotating contact arm.
You might also try to file the arm's actual rotating contact block to remove any past spark pitting.
I don't know if you can take your old unit apart to make necessary repairs & adjustments ?
If you can this might be just an easy repair adjustment.
Just a few thoughts if you cannot find another better, & newer replacement lighting rheostat.
- Thank you received: 135
11 Mar 2013 23:37 #24767
Replied by 1748 S on topic 810-12 Cord instrument light rheostat availability
If the reostat you found and are testing is flickering then I feel its shot. There should be smooth light intencaty as you increase the nob.
- stroker
11 Mar 2013 22:24 #24763
by stroker
810-12 Cord instrument light rheostat availability was created by stroker
Gents- I need a source for an instrument light rheostat that would fit. Also, are higher intensity bulbs available in 6 volts? What I've ginned up so far with an old found rheostat is a rather dim illumination, and when rotating the rheostat I get flickers.
Any thoughts or resources would be greatly welcomed!
Pete Rhoads
Pete Rhoads
