- Thank you received: 136
Horn Relay
01 Mar 2014 22:11 #27137
Replied by 1748 S on topic Horn Relay
Thanks for the help but sadly I do not have that news letter or the dvd to look it up.
- 5-ht
26 Feb 2014 06:05 #27120
by 5-ht
Replied by 5-ht on topic 810 - 812 Horn Relay
In issue #9 of 1990 Newsletter on page 5 there is a good close up picture of the RBM horn relay.
- Tim Gilmartin
- Thank you received: 57
23 Feb 2014 19:38 #27098
by Tim Gilmartin
Replied by Tim Gilmartin on topic Horn relay
In one of the past Newsletters there is a good picture of the horn relay and a small accompanying article. Check your DVD for the year and issue number.
Tim.
Tim.
23 Feb 2014 06:48 #27094
Thanks for the picture Tom. Thats the area I'm refering too. On that small area my firewall has what looks like there was a bracket attached to the wall. then the relay probably attached to side bracket. Don't recall what I had in this location if anything.
23 Feb 2014 04:32 #27093
by Tom_Parkinson
Replied by Tom_Parkinson on topic Horn Relay
Hi,
I am attaching the photos my dad took as he disassembled my Cord 1509A back in 1950. He barely caught the horn relay in the pictures.
Although the Startix had been replaced with a starter relay, I have no reason not to believe that the horn relay is original.
Hope this helps.
Hope this helps.
22 Feb 2014 20:13 #27090
Horn Relay was created by 1748 S
I understand the horn relay mounts to the lower passenger side firewall. Seems my location needs what looks like a bracket that has 2 screw holes about 4 inches apart. Is there a bracket that the RBM horn relay mounts to . Thanks for any pictures or information.
