- Thank you received: 136
What A Mes I found
I think I have you beat by one year. The last time 1509A moved under its own power was September, 1950, when my dad, my brother, a neighbor, and a lot of cussing got it backed into the garage.
The neighbor used his boot to hold the vacuum shift lever in place. My brother guided my dad's driving since there is no visibility through a sedan's rear window. The cussing came from the fact that the reverse gear had virtually no teeth on it. My contribution was to scream and cry in my play pen!
THANK YOU for the drawings and info, delivered by the good services of the USPS.
What a treasure trove! Since 1509A's drive train will be assembled in the next month or so, this is timely AND essential information.
Thank you Again!
Thank you, Tim. I look forward to seeing the drawings and info.
What a great club! Comes from having great people!
- Tim Gilmartin
- Thank you received: 57
Inner C/V joint: both of mine were in good shape; as you know, they are riveted together. A thorough cleaning in the wash tank, followed by soap and water; let dry. The filling of the cavity with grease was a two person job; one holding each shaft, twisting and turning, while the other used the gun to fill every possible gap. You will use most of a tube. Your silver cad plated C/V cover and the associated screws should be ready beforehand. Thoroughly clean out every screw hole; notice that most of these holes go directly into the transmission oil area. This could be a good source of leaks from the transmission side, so use gasket sealer on those screws. Once the inner C/Vs are in place, let them sit idle for a day or so to allow the gasket sealer to set.
Outer C/V joint: They come apart. You may have large ball bearings bouncing around the floor! Again, thoroughly clean in the wash tank, then soap and water. Let dry. I found two of the ten balls had pits in them, so I replaced with new. We found that these outer shafts etc. were made of some serious hard metal. Little if any wear was found. On the short shaft, remember to remove the screw that closes up the refill area. Once you have completed this whole operation properly, you may never have to mess with the C/V joints again! And never refill again! Paint anything that needs it,,,now. When you are ready to place the outer C/Vs, again a two person operation. The outer casing is held in place by the king pin assembly, so one holds the joint and the other maneuvers the casing and the king pins into position.
There is an overflow tank on top of the top kingpin. It does serve a purpose. As the grease heats up, and pressure builds, and the shafts are bouncing up and down on the road, any excess needs a place to go, and not by blowing out a seal. I found that after 12,000 miles, my overflow tanks were about one third full. Again, thoroughly empty and clean.
While you're working in front of the car, what better time to clean, paint, and adjust all the steering mechanisms. Make sure all ball joints, cups, and springs are adjusted. Remember a little play in front means a lot of play up at the steering wheel.
We're lucky here in Denver to have three excellent bearing supply stores. We did have to wait 48 hours for one seal. I even took parts over to them so they could see what we were talking about, and to take measurements, make suggestions, etc. I also had access to a lift. The entire front end sheet metal was off, so we had plenty of room to work, and at the right height.
I learned (the second time around) that the designers back in '36 weren't all that bad considering what they had to work with. Take your time and do it right the first time...then you don't have to come back and redo it.
I hope this helps. Any constructive comments appreciated.
Cordially, Tim.
- Tim Gilmartin
Please CC me on any specs and drawings that you may be sending.
- Tim Gilmartin
We replaced all the seals and gaskets with modern ones. We disconnected the joints and found a few balls either slightly cracked or pitted. Replaced with NOS ones I had. The manual says to fill each joint with one pound, or about one tube of grease. We used a marine application grease, but any heavy duty should work. One tube certainly fills the whole area. Make sure the brass part fits snugly on the shaft as that protects the seal.
I can look in my notes as to what seals etc. we have used. Any screw or bolt that goes into oil should be coated with gasket seal to prevent leaks. I am pleased to say there are no leaks...so far.
We had to use "speedy sleeve" on the worn parts of the shaft in order to have a good seal.
Would be happy to answer any questions you may have. Use my email.
CORDially, Tim.
I sent you a PM.
When I finally took apart my outer u joint I found the original leather seals on everything. I have 2 original leather seals for the outer bells too and somehwere I have a tall square can of Cord Univeral Joint oil. I think thw writing on it was green but its been many years since I have seen it. This was the very heavy stuff. When I opened up the outer u joint I found some very heavy oil like mess thats very slow to drip or move. I have not tried removing it yet. Just set the housing so it will drip out on its own. Probably going to warm up some diesel fuel to rid the housings of this stuff. Might do the same for the u joints with the balls too. I really don't want to remove the balls but I will if I have to.
- E L
- Thank you received: 25
This spring and summer I will be re-assembling all this stuff for 1509A. It's going to be a seat-of-the-pants experience likely to be marked with oil and grease leaks and drips until I get it right. The last time these parts were in an assembled status was in 1950.
Does anyone have an exploded diagram of the front axle/bearing/hub assembly that I could follow?
