- Thank you received: 136
Outer U joint Bearing
- Mark Tomei
I have the above-mentioned list of bearings and seals. Lord knows WHERE I got it from, but it's on my 'puter as a PDF.
If I managed to do the photobucket thing right, they should appear below.
Maybe these will be of assistance.
- Mark Tomei
- George van Nostrand
- Thank you received: 35
Two corrections are needed: Rear Wheel inner cone "2738 " should read
2788, Kingpin Lower Cup " A-6175 " should read A-6157 , this error also in
the Club Transmission Book list.
Front Wheel Bearing: N.D. 5509 ( 1 shield) & N.D 55509 ( 2 shield )
I found New Departure No's on the box as above, but bearing No. was
5209, and shield No. was 5509. Note that most of the replacement No's
have 5209 as their basic number.
Bearing numbers have always been a bit of a mystery.
Hope this helps.
George.
- Mark Tomei
- Mark Tomei
- Mark Tomei
Hi. Mike is spot on with that advice. The bearing you're looking for is a one-piece sealed double roller bearing. The correct part number is 55509. I would caution you to pay close attention to the actual numbers in the description. Many eBay bearing sellers are consolidators and industrial salvage people.
For what they're worth, these are links that I found when searching for info on front wheel bearings. And, in the cobweb-filled depths of my memory is a thought that the Cord front wheel bearings were special in that they were "tight" bearings--ie, no slop at all. 30 years ago they were hard to find. Now--anyone's guess.
forums.phpstack-1081784-3880776.cloudwaysapps.com/phpbb2/viewto ... nt+bearing
www.jsasoc.com/Family_archive/Ar ... %20810.pdf
