- Thank you received: 35
needing help
- George van Nostrand
19 Sep 2017 19:21 #33579
by George van Nostrand
Replied by George van Nostrand on topic needing help
The sixth brake spring is used on the Bendix brake with the " secondary stop ". It holds tension on the secondary ( rear ) shoe when adjusting clearance with the cam adjustment.. This brake was used on Cord 812, Auburns 33-36, Cadillac, LaSalle, Olds,Pontiac, some Packards. Reference- Grey-Rock Brake Service Manual.
16 Sep 2017 23:22 #33574
by RandyEma
Replied by RandyEma on topic needing help
Take it off see what it does
- martin0
16 Sep 2017 02:48 - 29 Oct 2017 02:42 #33572
by martin0
needing help was created by martin0
The Bendix brake design uses six springs on each wheel. There are two return springs, two hold down, one for the adjuster. What is the function of the sixth spring? I am really confused. Could someone help me.
Last edit: 29 Oct 2017 02:42 by martin0.
