Cord Trans Washers
- eaj564
06 Apr 2018 11:42 #34429
by eaj564
Replied by eaj564 on topic Cord Trans Washers
I made our washers from 8620 and case harden Rc 58-62. Keep in mind to leave .007 to.010 stock on thickness and bore for grinding after heat treat, they will warp. I made the 2nd gear thrust washer from 660 bronze.
05 Apr 2018 14:08 #34424
Replied by 1748 S on topic Cord Trans Washers
After much more reading and re reading the Ayers manual from the club I found the washer material suggestion to be 8620. It also noted the washers needed to be heat treated too but I have not found to what hardness yet.
04 Apr 2018 01:30 #34417
Cord Trans Washers was created by 1748 S
In our trans are washers on the 2nd, 3rd and 4th gears.Can someone tell me what material these are made from? My plan is to machine them myself on my lathe. I plan to purchase the heavy washer that is slid over the third gear sleeve. Thats the washer that has ruined many a trans in the past. Mine was modified to a thickness of .300 up from .250. It was not the 3/8 inch size. My sleeve was also modified to fit. Thanks for any help too.
