Horn Ring
06 May 2023 02:47 #47158
Replied by Terry Cockerell on topic Horn Ring
Adam the drawing is attached.
When I assembled mine I had to make the screw with the locating pin to suit.
I used stainless steel rod then you don't have to bother with chrome plating.
- LumsdenLive
06 May 2023 01:27 #47157
by LumsdenLive
Adam Lumsden
1936 Cord 810 Westchester 1710A
Replied by LumsdenLive on topic Horn Ring
Sorry to resurrect an old thread. Terry can you forward the mentioned photos to me? My wheel is apart and someone has modified the horn ring mounting from factory.
Adam Lumsden
24 Apr 2020 13:26 #40003
Replied by 1748 S on topic Horn Ring
Thanks Terry. Your great pictures of the actual horn installation and springs showed this screw. I looked at my wheel and found this screw in place. I used some Aerokroil on it before I tried to unscrew it believing it was going to be very tight. Nope. Found no issues.
24 Apr 2020 08:13 #40001
Gary there is a Horn Ring Locking Screw that is located on the underside of the steering wheel. The screw has a round pin on the end that locates "from memory" in one of the horn ring arms. I will check this tomorrow.
24 Apr 2020 02:55 #40000
Horn Ring was created by 1748 S
I have seen many Cord horn ring placement differently on so many cars. My thought is the horn ring needs to be "clocked" to match the wheel spokes. But so many are placed what seems to anywhere. Is there are reason for this? Just wondered...
