- Thank you received: 17
What type of engine?
- alsancle
Tom_Parkinson wrote: A Nash 8. Hmmm It'd make a good snowblower engine.
Well, for the 600+ someone bucks bid for this engine, I would have bought it just for giggles and entertainment. I wonder what the seller's reserve was? Considering that the world market for this engine is likely about 3 people, I doubt that it has much value.
It's one of those things where if you need one it's value is incredible, but if you don't then it has none.
- Bicknell
Bill - Email: <a href="mailto:[email protected]][email protected][/url]
- project1
- Bicknell
Bill Bicknell
- Chris Summers
mikespeed35 wrote: Are you aware that the Nash 890 is a Full Classic. Engine 298 cu. in. 115 HP. Very comperable to the Auburn big eight.
...And commonly referred to as "Kenosha's Duesy" due to its luxury and high standard of finish.
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
- alsancle
[url:3k5hkkch]http://cgi.ebay.com/ebaymotors/1931-Nash-890-Twin-Ignition-Eight-engine-to-rebuild_W0QQitemZ270400791366QQcmdZViewItemQQimsxq20090601?IMSfp=TL090601153001r13985[/url:3k5hkkch]
- NNICKB
If you want something really, well, different, you might consider the Jeep Tornado 6. It does have "the look," well, sort of. There was a version of this engine used in the Argentinian Rambler Torino, with triple Weber carburetors.
NNICKB
- project1
Anyone able to post photos of engine Prey's Duesy 12?
E. Killorin
- project1
- georgealbright
George Albright Cell 352 843 1624
- project1
- Bicknell
Regards,
Bill
- hportz
www.portzcordz.com (photos)
- paul111
hportz wrote: Paul 111, The biggest problem with a Jag 3.8 or 4.2 tripple SU carb engine is the people that work on them! It might look a little small in that car though. Have fun! 31631F Henry
And what's wrong with the people who work on them - I am now one of them so I need to know!!!
- paul111
I agree it will look a little small so I shortened the engine bay about 3 inches, hopefully not enough to make it noticable from the outside and also will be using the radiator, shroud and fan to take off another 5 or six inches on the length at the front. I will also push the engine forward so the bell housing and gearbox does not intrude into the firewall. Couldn't really do anything about the width but I think the manifold, carbs and filters on the one side and a big custom exhaust header on the other will fill the width fairly well.
The rest of the space I hope to fill in with other engine stuff that will take up a little more space than usual.
- project1
- hportz
- project1
- alsancle
project1 wrote: Buick collectors have dabbled with various cylinder head conversions including a cross-flow twin cam by grouping a pair of Toyota or Alfa heads. Complex and expensive for little gain. Stick with the stock Buick engine/apperance and add a few authentic go-fast goodies, or save your change for a real J Duesy engine. Alternatively, take a look at the relatively inexpensive eight cylinder Stutz SV engines (single cam) or pricier DV32 (twin cam), the latter a direct rip off Model J.
I believe they were more or less developed independently of each other although the Stutz was much later to market. It is a superior design that does not require shims to adjust the valves like the Duesenberg.
A Single ovehead cam Stutz engine will set you back about 5k and then about 20 to 25 to properly rebuild it. The DV32 engine is more or less unobtainable but would probably run you 35 to 45k plus rebuild if you actually found one.
Btw, what I was referring to was bolt on parts for the Buick in appearance only. Not a functioning overhead cam setup.
- paul111
I just last week bought a Jag engine and I am in the process of rebuilding it.
I did look at and do some research on Buick and some other straight 8's but couldn't bring myself to go that direction as I have no experience with any of them and was a little afraid of the unknown. Better the devil you know.
Anyway I think with a little modification I could make it look quite similar to the Dues. as it is a similar engine configuration.
Must admit I have never seen the Stutz but I am sure it's a pricey option.
- project1
- Bicknell
- alsancle
- project1
- Bicknell
Bill
- paul111
"A Quad 4 (now Eco-Tech) trimmed properly looks almost identical to a vintage Offy."
Now ther's an idea, a miller straight-8, do you think I could get one of those for less than $5000!!!!.
www.milleroffy.com/miller_milton_122_3.jpg
OK I might be tempted to spend a bit more if I could get one of those. <!-- s:lol: --><img src="{SMILIES_PATH}/icon_lol.gif" alt=":lol:" title="Laughing" /><!-- s:lol: -->
- Steve Derus
- Greg Riley
Take a look here: [url:bnph2alv]http://www.quad4rods.com/[/url:bnph2alv]
I thought it would be fun to create a "Baby Duesenberg" replica using one of these, and a Tremec 5-Speed.
Greg Riley
- paul111
- bill powell
- Steve Derus
Steve Derus
- Chris Summers
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
- paul111
Let?s say you built a replica of a model J with exact dimensions, what type of engine would you put in it if your budget was around $5000?
While most automatically put in the V8 I tend to think that, not only does it not fit properly (too wide and short) it does not suit the period very well. My thoughts are it has to be an inline engine. While there are a few old straight-8?s around there are none that look close to the original, I am thinking the old Jaguar straight-6 with twin overhead cams is a very similar looking engine to the original and with 3 twin sidedraught webers would look very nice and perform well too.
www.classicjaguar.com/062505db1.jpg
www.classicjaguar.com/webers.htm
Anyone have any thoughts?
