Stromberg UUR 2 Carburetors
- pgb123
30 Jan 2020 21:56 #39430
by pgb123
Replied by pgb123 on topic Stromberg UUR 2 Carburetor Adjustment Procedure info
Hi Ed,
I am out of state for the next few weeks seeking warmer weather.
My email is [email protected]
home is 207-727-5855
Paul
Paul
30 Jan 2020 19:26 #39429
by pete kelly
Replied by pete kelly on topic Stromberg UUR 2 Carburetor Adjustment Procedure info
Try phone 207-727-5855
- Ed Q
30 Jan 2020 16:30 #39428
by Ed Q
Replied by Ed Q on topic Stromberg UUR 2 Carburetor Adjustment Procedure info
How do I get an email address for pgb123 ?
I would like to get the info for this Carb Adjustment Procedure if you please.
Ed Q
Ed Q
28 Jan 2020 05:25 - 28 Jan 2020 05:27 #39422
Replied by mikespeed35 on topic Stromberg UUR 2 Carburetors
I use reg. ethanal in everything excerpt my higher performance 60's cars. Those I use what ever the high octane is at the station. When driving longer distances you can't be choosy.
Last edit: 28 Jan 2020 05:27 by mikespeed35.
- pgb123
27 Jan 2020 22:16 #39419
by pgb123
Replied by pgb123 on topic Stromberg UUR 2 Carburetors
We cannot get nonethanol gas in Maine.
I agree using 91 grade.
I use some Marvel Mystery oil in the gasoline and it does make a positive difference in long term storage and starting the car
Paul Barese;
Paul Barese;
- Thank you received: 135
26 Jan 2020 02:36 #39402
Replied by 1748 S on topic Stromberg UUR 2 Carburetors
Never run regular unleaded. It has ethanol and it gums up any carb. Run the premium unleaded.
- Ed Q
25 Jan 2020 17:34 #39398
by Ed Q
Replied by Ed Q on topic Stromberg UUR 2 Carburetors
How do I get your email address ? for this Carb Adjustment Procedure.
Ed Q
Ed Q
- pgb123
19 Jul 2018 11:32 #34994
by pgb123
I have a 1929 Studebaker President which uses the Stromberg UU2 carb. The service manual describes a pretty lengthy method of adjusting the carb.
I was a small engine and tractor mechanic for years and have found the basic settings of small engines to work on the UU2. I carefully turn in and botton out both idle adjustments. DO NOT over tighten or you will damage the adjustment needle. Turn out the screws 1 1/2 out.
The fuel pump accelerator needs to be bottom out and turned 1 1/2 out. These are basic settings. Start the engine and let it warm up. Turn in the idle screws if running too rich. Turn both idle screws in very slowly and stop. Let the engine settle as the adjustment will be some where in the 1 1/4 range.
The same for the accelorator pump. It will be about 1 1/4 turns out. Give it the gas and see how it sounds. Do not get carried away and to a 1/4 turn each adjustment. Go Slow. If you email me with your address, I will send you the adjustment proceedure. Also, I use high test fuel and add marvel mystery oil. These early engines run better on a high test fuel. Hope this helps
- Dave M
01 Jul 2018 03:18 #34884
by Dave M
Stromberg UUR 2 Carburetors was created by Dave M
Hi
Does anybody have any experience with this Carb ? Or can you provide setup/adjustment procedure ?
