#8 finish washer/ raised recess dimple dies for running board trim moulding
- pneflyer
23 Apr 2021 17:56 #42949
by pneflyer
Replied by pneflyer on topic #8 finish washer/ raised recess dimple dies for running board trim moulding
Try searching "punch dies". A quick Google search came up with 1/4"
- hessacres
23 Apr 2021 16:53 #42948
by hessacres
Replied by hessacres on topic #8 finish washer/ raised recess dimple dies for running board trim moulding
McMaster Carr has some dimple dies, but the smallest is 1/2 inch hole. A #8 screw is a much smaller hole. I do not know another term for a dimple die. If you search “dies” you get thread dies.
23 Apr 2021 03:59 #42945
Replied by mikespeed35 on topic #8 finish washer/ raised recess dimple dies for running board trim moulding
Not sure what exactly you are looking for but McMaster-Carr has lots of stuff like that. The trick is to know the proper description.
- hessacres
23 Apr 2021 03:15 #42943
by hessacres
I am familiar with Restoration Supply. They sell running board trim and #8 finish washers. These would be close to the original design. But if possible I would like to press the raised recess into the trim as the orginal. I have not seen any dimple dies in their latest catalog. Do they have items not listed, or have I missed them somehow.
- Thank you received: 219
23 Apr 2021 02:03 #42942
Replied by JIM.OBRIEN on topic #8 finish washer/ raised recess dimple dies for running board trim moulding
Try Restoration Supply Company -
www.restorationstuff.com
I think they have what you are looking for.
- hessacres
22 Apr 2021 03:29 #42933
by hessacres
1922 Duesenberg
22 Apr 2021 01:29 #42931
What Car?
- hessacres
21 Apr 2021 19:55 - 21 Apr 2021 19:57 #42927
by hessacres
#8 finish washer/ raised recess dimple dies for running board trim moulding was created by hessacres
I am trying to redo the running boards on my car and am having a hard time finding a #8 finish washer or sometimes called a raised recess dimple dies for the running board trim molding. I can find #10 ones but not #8, unless i buy a whole set. I only need to do 26 holes so do not want to spend a fortune on a set. Anyone have one or know where I can get one?
Last edit: 21 Apr 2021 19:57 by hessacres.
