Auburn radiator
  • JOEL GIVNER
15 Jul 2008 14:36 #10705 by JOEL GIVNER
Replied by JOEL GIVNER on topic Auburn radiator
Beauty is in the eye of the beholder
JEG
  • ilikescars
14 Jul 2008 18:47 #10693 by ilikescars
Replied by ilikescars on topic Auburn radiator
I finally decided to go ahead and take the radiator out of my car. It requires removing a dozen bolts from the front fender area, two nuts that hold the radiator to the frame, and four bolts that hold the cowl to the radiator. Drain out the coolant and remove two rubber hoses. Old hoses would probably need to be cut out. Actually, a pretty simple process. Reassembly will most likely be more difficult, I presume. An Auburn looks pretty sad without it's cowl, doesn't it?
  • ilikescars
15 May 2008 00:32 #10097 by ilikescars
Auburn radiator was created by ilikescars
I'm thinking about changing-out the radiator in my Auburn cabriolet. I want to install a "honeycomb" style radiator. Has anyone done this on a finished car? How difficult is it? What steps have to be taken?
I don't want to wreck the car in the process, so I thought I'd ask first.
