- Thank you received: 135
Flywheel torque specs
10 Nov 2018 18:33 #35934
Replied by 1748 S on topic Flywheel torque specs
In my restoration I have "found" so many bolt threads that are fine threads where in normal engines of today they are coarse threads. I too found this out the hard way when I tried to "clean up" so threads in the block mounting holes for the motor mount plates. Its like measure twice... Cut once...
10 Nov 2018 17:30 #35933
Replied by johnmereness on topic Flywheel torque specs
Take extra time to make sure it is all correct bolts, double check everything, and ... - I had to basically throw away what should have been a beautiful flywheel, clutch disk, and pressure plate that probably only had 10 to 15 minutes of driving on them because somehow junk hardware store bolts of wrong size got installed - unbelievable the damage to each in such a short period of time and just lucky that was extend of it
09 Nov 2018 03:37 #35925
Replied by mikespeed35 on topic Flywheel torque specs
That's called torque till yield! I hang my head in shame, I have done that!
08 Nov 2018 15:22 #35924
by ilikescars
Replied by ilikescars on topic Flywheel torque specs
Or as a friend said: Tighten bolt until it strips, then back off a quarter turn.
(humor)
(humor)
08 Nov 2018 13:25 #35923
Replied by Curt Schulze on topic Flywheel torque specs
Good point Mike.
08 Nov 2018 04:07 #35920
If you eliminate lock washers for Loctite products you may end up with bolts that are too long and bottom out or interfere with something else. If you want to use Loctite go ahead. but use lock washers too if called for.
07 Nov 2018 19:04 #35919
Mark, you will not find any torque specs for anything in the technical bulletins. Torque wrenches were not available until WWII
The book calls for lock washers , use new ones.
07 Nov 2018 14:48 #35918
by ilikescars
Flywheel torque specs was created by ilikescars
I believe the torque for flywheel bolts should be 60 ft lbs, but I'm not sure. Also, the parts book calls for lock washers, but thread locker might be a better idea for this. Looking for other people's experience
