  • 1748 S
  • Platinum Forum User
24 Sep 2018 03:25 #35480 by 1748 S
Replied by 1748 S on topic Cord 812 Custom Beverly restoration story
Upgrading these bolts is a good idea. My car shows the passenger side fell and the spring ground along the road nearly cutting the ends off. I will post pictures tomorrow. Also at one time my car probably lost a wheel on the passenger side too. The bottom of the brake backing plate is also ground off. Last year I purchased the heavy duty bolts and all the cups and special nuts. Glad I did this.
  • JIM.OBRIEN
  • Premium Forum User
23 Sep 2018 22:30 - 23 Sep 2018 22:30 #35479 by JIM.OBRIEN
Replied by JIM.OBRIEN on topic Cord 812 Custom Beverly restoration story
Hi Youenn,
Last edit: 23 Sep 2018 22:30 by JIM.OBRIEN.
  • 1748 S
23 Sep 2018 21:32 #35477 by 1748 S
You do wonderful work. Please continue to post pictures so everyone can enjoy.
  • RubyDS
23 Sep 2018 19:29 #35474 by RubyDS
Replied by RubyDS on topic Cord 812 Custom Beverly restoration story
After receipt my new throw out bearing (thanks Jim) i can assembly my engine and gearbox
[img
[img
And install the new bearing of front axle and add grease nipple.
[img
[img
  • RubyDS
11 Sep 2018 14:13 #35393 by RubyDS
Jim you have a PM
  • RubyDS
12 Aug 2018 20:48 #35211 by RubyDS
Thanks Jim
  • JIM.OBRIEN
12 Aug 2018 20:23 #35210 by JIM.OBRIEN
I just sent you a PM.
  • RubyDS
12 Aug 2018 16:11 - 12 Aug 2018 16:12 #35208 by RubyDS
Ready to install my gearbox on the engine.........problem!!!!!! the clutch throwout bearing buy whith the car is probably not the correct model,i looking for this parts if anyone have.
And for the clutch axle bearings,the correct number is NB-110?
Last edit: 12 Aug 2018 16:12 by RubyDS.
  • Curt Schulze
26 Jul 2018 12:01 #35063 by Curt Schulze
Replied by Curt Schulze on topic Cord 812 Custom Beverly restoration story
I have rear view mirrors like the one in the pix, if you need one.
  • Terry Cockerell
  • Elite Forum User
26 Jul 2018 09:27 #35062 by Terry Cockerell
Replied by Terry Cockerell on topic Cord 812 Custom Beverly restoration story
I think the mirror is upside down in the maroon Cord. You should get a better rear view by turning it around. The attached picture is of a very original unrestored Cord.
  • 1748 S
26 Jul 2018 03:21 #35061 by 1748 S
wow the first reverse cluster gear is in bad shape but so is the first reverse slider gear.Are you replacing the gear bushings? Are you hard chroming the shaft the gears ride on??? Sure is plenty of work in these transmissions. I'm machining and rebuilding my trans now as you are.
  • RubyDS
25 Jul 2018 07:20 #35058 by RubyDS
Speedometer in kilometer
  • RubyDS
25 Jul 2018 07:17 #35057 by RubyDS
Marroon 810 gearbox
  • RubyDS
25 Jul 2018 07:15 #35056 by RubyDS
  • RubyDS
25 Jul 2018 07:11 - 25 Jul 2018 07:14 #35055 by RubyDS
Yes Johnathan,it's two 810 weschester,i have make a lot of little work on the green one,this car is tested in a french magazine "Retroviseur" this month and i have rebuilt the gearbox of the marroon one,car sold new in France in 1936 with speedometer in kilometer.
For the Soccer it's not my thing............ ;)
Last edit: 25 Jul 2018 07:14 by RubyDS.
  • Jonathan Richards
24 Jul 2018 21:47 #35054 by Jonathan Richards
Replied by Jonathan Richards on topic Cord 812 Custom Beverly restoration story
Greetings , Youenn Perrin , aka RubyDS., You are just having too much fun in your delightfully aged garage/shop in France. A visit to your shop by a Ganges Green Westchester followed by a similar visit by a Rich Maroon Model 810 which appears to be a Westchester as well. Your Custom Beverly is shown lurking in the background as she comes closer and closer to reaching your restoration goals. Keep up the excellent work and the flow of periodic messages to our ACD Club Forum. Oh, yes , congratulations on your Soccer Cup victory if that is your thing. Best Regards, Jonathan Richards #1080 at Chesterfield, Missouri , USA.
  • RubyDS
24 Jul 2018 21:24 #35053 by RubyDS
After a green 810 a few month ago in my workshop this week a maroon 810 B)
  • RubyDS
29 Jun 2018 14:21 #34853 by RubyDS
  • RubyDS
29 Jun 2018 14:20 #34852 by RubyDS
Ready to instal on front axle
  • RubyDS
28 Jun 2018 08:15 #34849 by RubyDS
  • 1748 S
27 Jun 2018 18:25 #34846 by 1748 S
My bearing is a National 7109. These bearings are common in several other cars too.
  • RubyDS
27 Jun 2018 16:05 #34845 by RubyDS
I'm ready to assembly engine and gearbox and i looking for the reference (number)of the bearing at center of the flywheel.
  • Terry Cockerell
  • Elite Forum User
23 Jun 2018 06:53 #34820 by Terry Cockerell
Rudy, continuing with the alternative method proposed by Henry Portz you will need spacers between the outer cups.
Mine worked out with the following dimensions. Outside diameter 2.5" Inside diameter 2.125" Width 0.5"
  • mikespeed35
23 Jun 2018 03:57 #34818 by mikespeed35
Replied by mikespeed35 on topic Cord 812 Custom Beverly restoration story
I toured with the Past president of Timken a few years ago and he told me there are alternatives to some of the rear extremely expensive bearings and races as you can see here. A little research is required and a cooperative bearing counter man.
  • Thomas Wilcock
  • Senior Forum User
22 Jun 2018 12:43 #34814 by Thomas Wilcock
Replied by Thomas Wilcock on topic Cord 812 Custom Beverly restoration story
I should have said that Timken # 13890 is the bearing cone.
Tom
  • RubyDS
22 Jun 2018 12:32 #34813 by RubyDS
Perfect Terry,
I have cone 13889 and have ordered 4 cup 13830 availlable next week,many thanks
  • Thomas Wilcock
  • Senior Forum User
22 Jun 2018 12:30 #34812 by Thomas Wilcock
I used the Timken 13835D double row race and Timken 13890 cup. Unlike the original double row race I removed, the new Timken 13835D had holes around the center for lubrication. I drilled the bottom retainer bolt for the bearing housing and installed a grease fitting so that the bearings can be greased occasionally.
Tom
  • Terry Cockerell
  • Elite Forum User
22 Jun 2018 08:26 #34810 by Terry Cockerell
Rudy the bearing numbers I have listed are.
M28241 / 1R2424 ......... is the needle bearing assembly
138890 .............................. is the taper roller cup
13830 ................................. is the taper roller bearing cone
The outside diameter of the bearing is 2 1/2" which fits inside the outer bearing block.
I can't remember the shaft size of the suspension arm
Any bearing company should be able to readily supply these parts.
  • RubyDS
22 Jun 2018 06:20 #34809 by RubyDS
Interesting but have you the timken number used for that?
  • Terry Cockerell
  • Elite Forum User
21 Jun 2018 23:32 - 22 Jun 2018 00:38 #34805 by Terry Cockerell
Henry Portz suggested using two separate taper roller bearings with a spacer between the outer cups then tightening the big nut on the pivot shaft to 8 ft lbs with the nut free running on the thread. This is a much cheaper option as the bearings are readily available. Grease nipples can be set up to feed the inner needle bearings with a tube passing through the centre of the pivot shaft. Grease nipples can also be added to the taper roller bearing housing. I followed Henry's guidelines which are laid out in an old newsletter. I will look for the details and post them in this Forum.
Last edit: 22 Jun 2018 00:38 by Terry Cockerell. Reason: Adding attachments
  • uconn_1965
21 Jun 2018 19:34 #34804 by uconn_1965
Replied by uconn_1965 on topic Cord 812 Custom Beverly restoration story
Double row race Timken 13835D
bearing Timken 13890
  • John Meredith
  • Senior Forum User
21 Jun 2018 19:15 #34803 by John Meredith
Replied by John Meredith on topic Cord 812 Custom Beverly restoration story
This is an interesting discussion. So, when asking about the races and the bearings, what do I ask for when talking with Baystate Bearing and the North Carolina supplier? Are there specific Timkin numbers? ... John M.
  • RubyDS
21 Jun 2018 17:50 - 21 Jun 2018 17:51 #34801 by RubyDS
Yes I found at my bearings supplier in France,but 300€ each +/- 280$ availlable in Timken USA,it's very expensive for just a timken cup, i have the new roller bearing.
Last edit: 21 Jun 2018 17:51 by RubyDS.
  • uconn_1965
21 Jun 2018 17:14 #34800 by uconn_1965
I recently bought a pair of these double row bearing races from a local bearing supplier BUT I almost feel over with
the price. They were $280. each. I also bought the 4 bearing that fit these races from a different supplier (old car bearing co.) in
North Carolina. I think they were $35.00 each. I purchased the double row races from Baystate Bearing co., 138 Reed Ave.,
West Hartford, Ct. 06110 phone number (860) 953-0055. Hope this helps....Cliff
  • 1748 S
21 Jun 2018 16:20 #34799 by 1748 S
Sad news is these bearings are no longer made. There is a very slight hope someone has a set of NOS bearings but it was discussed on this forum a few years ago. Nobody had any at that time. checking ebay is about the best way to find something but you just have to "bee there" when they might get listed. A restorer in Europe machined a set of bushings in place of the bearings. If that's what you end up doing it probably would be a great item to install grease fittings. Remember these inner and outer bearings are moving up and down all the time with every small bump in the road.
  • RubyDS
21 Jun 2018 16:06 - 21 Jun 2018 16:14 #34797 by RubyDS
For my front axle i'm looking for two double cone cup 1335-13835 ,new,Nos or used in correct condition.
Who have that in stock?
Last edit: 21 Jun 2018 16:14 by RubyDS.
  • 1748 S
18 Jun 2018 22:56 #34773 by 1748 S
I had no idea this book was this size. It reminds me of the Josh Malks CORD COMPLETE book. Thank you for sharing too.
  • RubyDS
18 Jun 2018 20:44 - 18 Jun 2018 20:45 #34772 by RubyDS
Just receipt a parcel this day ,the incredible gift from Mike,many many many thanks,it's amazing,i'm very happy.
Last edit: 18 Jun 2018 20:45 by RubyDS.
  • RubyDS
10 Jun 2018 11:02 #34755 by RubyDS
PM sent Jim.
  • JIM.OBRIEN
10 Jun 2018 01:53 #34754 by JIM.OBRIEN
RubyDS, This is the wrong master cylinder for the Cord. However it will work. Outside of Auburn not many people will know. If you want a correct on PM me, I think I have a couple of spares.
  • 1748 S
10 Jun 2018 00:37 #34752 by 1748 S
Here are the pictures of my master cylinder. Turns out it was a Wagner Lockheed but my brakes are Bendix.
  • Curt Schulze
09 Jun 2018 21:58 #34751 by Curt Schulze
The Lockheed and Bendix master cylinders are almost identical . They will interchange. I believe the company used both on 34-36 Auburn. Which ever they could buy the cheapest.
  • RubyDS
09 Jun 2018 21:43 #34750 by RubyDS
Yes Curt,25,4 mm equates to 1 inch
1748S i think have lokheed brakes, i will check
  • Curt Schulze
09 Jun 2018 18:31 #34749 by Curt Schulze
I attempted to attach a scan of the 34 parts book as a PDF but I don't think it worked.
  • 1748 S
09 Jun 2018 17:42 #34748 by 1748 S
That master cylinder looks like the wrong part for your car. My car has a Bendix brake system on it. My car is a 1937 and serial number is 1748S. The 36 and 37 Cords had either Bendix or Wagner Lockheed brakes. Can you tell this forum what brakes your car has? If you don't know the difference. The Bendix brake shoes adjust from the bottom by the star wheel. the Lockheed adjust by the bottom but from the back of the backing plate. ebay has a good picture of the Lockheed brake backing plates for and example. I can post pictures later on what my master cylinder and brakes look like.
  • Curt Schulze
09 Jun 2018 12:19 #34745 by Curt Schulze
That looks like the same master cylinder Auburn used 1934 - 1936 25.41 equates to about 1 inch doesn't it?
  • RubyDS
09 Jun 2018 08:46 #34744 by RubyDS
Picture of the master cylinder
  • JIM.OBRIEN
09 Jun 2018 01:39 #34741 by JIM.OBRIEN
If I remember correctly the original size was 1 1/8" Do you have a picture of your master cylinder?
  • RubyDS
07 Jun 2018 19:01 #34738 by RubyDS
I have buy a master cylinder repair kit diameter 1"1/8 and my master cylinder is in 1" diameter,what is the correct size?
[img
  • RubyDS
05 Jun 2018 07:12 #34722 by RubyDS
After five days of absence I am very happy to discover your message Mike, it's too much to want to give it to me as a gift,i send you a private message.
